New headunit connection question
HighSharpe
Post by HighSharpe » Sun 12 Oct, 2014 16:28
Hello all
My Z3 came with an aftermarket Sony unit with a CD player, but sadly no bluetooth/aux/MP3. I bought a non-fancy head unit with the above features, and got around to try fitting it this afternoon. I had read here that you need an adapter to connect and aftermarket unit, but I thought it would be a simple plug n play given that the existing headunit was aftermarket already. But, i find that the old unit is connected to another set of connectors behind the dash, and the connector block at the end of new unit arent the same as that of the old! Not sure what exactly is 'standard' .
Here are some pics to explain
1. Back of NEW unit
2. Back of OLD unit
3. Connector into old unit
4. Connector into old unit has wires leading into this :
So... what do I need to buy to make this work?
a/ an adapter that adapts (4) into (1) ,
or b/ an adapter that sits between (3) and (1)
Thanks !
-HS
David
Re: New headunit connection question
Post by David » Sun 12 Oct, 2014 16:46
I was under the impression that most new stereos came with a wiring harness that connects (as you described) 1 to 4.
Sorry to ask this but... Have you double checked the box for any cables? As I would say that pic 4 is the 'industry standard' connection.
HighSharpe
Post by HighSharpe » Sun 12 Oct, 2014 16:54
No, Davidz3, there was no harness that came with the stereo, it was an elcheapo chinese brand.
akirk
Post by akirk » Sun 12 Oct, 2014 17:30
Apparently everything is now standard... ...with the right adaptor! So I was told by a specialist store when upgrading a head unit...
I would suggest googling a decent independent car audio company - tell them what you have and I would imagine they will have a convertor which should be quite cheap...
Alasdair
David
Post by David » Sun 12 Oct, 2014 18:50
Ok, I've done a little search for you, and this seems to match up with the shape of the holes:
http://pages.ebay.com/link/?nav=item.vi ... 1484576027
Sending from my phone, so if the link doesn't work just put 181484576027 in the search box and click search.
HighSharpe
Post by HighSharpe » Sun 12 Oct, 2014 18:57
Thanks David, found some thing similar.
http://www.ebay.co.uk/itm/191206409470
However getting the wires mixed up could result in a toasted head unit or worse, so will have to figure out a way to test non-destructively!
David
Post by David » Sun 12 Oct, 2014 19:42
IMHO, you'd be better off with the one I linked, although it's more expensive, the postage (and possible import charge) and having to wait an additional week for the one you suggested, makes the little extra money seem definitely worth it.
...unless you are in the states that is!
t-tony
Post by t-tony » Sun 12 Oct, 2014 22:08
Visit your local Halfords, they keep a range of adaptive stereo cables. There are relatively inexpensive, I've used them before and have one in my 2000 Z3 connecting a Sony unit to the original loom plugs.
Tony.
Users browsing this forum: Yahoo [Bot] and 1 guest
