Hi all
can anyone tell me how the cigarette lighter comes out,and also where the fuse is for it,cause i need to relocate it ,when i plugged in the new sat nav yesterday i found that my hand kept touching it when changing gear.And its driving me
Maurice
cigarette lighter removal
I have the same problem, so bought a cigarette lighter extension lead with a right angle plug one end to go into the cigarette lighter socket, and a double socket at the other. I plug the sat nav into the double socket and stick it in the mesh holder on the passenger side and let the lead trail up to the window. Not pretty but it works.
2001 Titan Silver 2.2 Sport
The cigarette lighter is just a tight fit but can be a real PITA to remove.
Easiest way is to flick the gearstick gaitor off and attack from underneath
When I changed the head unit last year I fitted a spare cig socket behind the passenger toe panel.
I use for the sat nav and have a permanent multi-charger monkey LINKin the centre console.
