Like hens teeth.
Might not be cheap but you would always get your money back.
They are a striaght swap if you already have OEM rollhoops installed.
eBay
Ac Schnitzer Rollhoops on German eBay
Less than i paid for mine
Its the first time i've ever seen a set for sale?
just had a second glance and they are missing the correct mounting seals and front leather bits, they may not be genuine?
This is a google translate of the ad. Suggests they were re-chromed, which may explain the missing bits?
AC Schnitzer chrome roll bar from a Z3 M.
Last year were re-chromed.
Immediate purchase or exchange for AC Schnitzer Z3 M for possible fog.
Sale of private, no exchange, - guarantee - or money back guarantee.
Enjoy your offer!
Enjoy your offer!
BMW Z3 2.0 Titan Silver - Progress Thread
(Pictures - http://s852.photobucket.com/home/gazhyde/allalbums)
Is it not because they have been photographed from behind? thanks for the heads up though Shanty, quite fancy bidding but not if theyve been messed around with or in fact even genuineshantybeater wrote:just had a second glance and they are missing the correct mounting seals and front leather bits, they may not be genuine?
I would brush up on my german and contact the seller and ask if they are genuine Ac Schnitzer (nb Schntzer did not actually make them anywy but a firm called Alumex). If he states they are and they turn out not to be eBay will refund you if he disputes. I've done this even when I've not paid by Paypal and got my money back from eBay (even when just not as described).
No worries Tim, they do look like the right shape though (which none of the fakes i've seen have). As Jon said they were made by alumex and i'm pretty sure you could order direct from them (without the schnitzer branding) so it might also be that?TitanTim wrote:Is it not because they have been photographed from behind? thanks for the heads up though Shanty, quite fancy bidding but not if theyve been messed around with or in fact even genuineshantybeater wrote:just had a second glance and they are missing the correct mounting seals and front leather bits, they may not be genuine?
Anyway I would probably take a risk and go for it, or maybe contact Alumex first and see if they can still supply the hoops? Its unlikely you'll see another set up for sale anytime soon
Thanks Shanty, keeping a watchful eye on them, if I do go for them it means I would have too go for a another Z3 over a Z4 next yearshantybeater wrote:No worries Tim, they do look like the right shape though (which none of the fakes i've seen have). As Jon said they were made by alumex and i'm pretty sure you could order direct from them (without the schnitzer branding) so it might also be that?TitanTim wrote:Is it not because they have been photographed from behind? thanks for the heads up though Shanty, quite fancy bidding but not if theyve been messed around with or in fact even genuineshantybeater wrote:just had a second glance and they are missing the correct mounting seals and front leather bits, they may not be genuine?
Well you should definitely buy them if they will force you into making the right choiceTitanTim wrote:Thanks Shanty, keeping a watchful eye on them, if I do go for them it means I would have too go for a another Z3 over a Z4 next yearshantybeater wrote:No worries Tim, they do look like the right shape though (which none of the fakes i've seen have). As Jon said they were made by alumex and i'm pretty sure you could order direct from them (without the schnitzer branding) so it might also be that?TitanTim wrote: Is it not because they have been photographed from behind? thanks for the heads up though Shanty, quite fancy bidding but not if theyve been messed around with or in fact even genuine
