New youtube tag
Any site announcements will be made here. Also the place to make suggestions to help improve this site. Also use this forum for reporting suspected errors or for asking 'how to' questions.
New youtube tag
Post by Robert T » Tue 24 Jul, 2012 23:19
By popular request I have just added a new youtube tag, which you should see listed along the top of the posting area.
The new tag has the following format:
Code: Select all
[youtube=width,height]videoid[/youtube]
For example, to insert the video http://www.youtube.com/watch?v=n9h34xYsRrI into your post, find the video on youtube (just click the link to see this one). Make a note of the video id from either the address bar (it is the bit after ?v=) or if you click the share button, the bit after the last forward slash (/) in the youtu.be link. You will also need the width and height for the video, which you can get by clicking the Embed button which is displayed after clicking Share. At two points in the HTML display you will see width= and height= - you just need the numbers. The code for the example video looks like this:
Code: Select all
[youtube=560,315]n9h34xYsRrI[/youtube]
There is also a simpler version of the tag that does not allow you to set the width and height:
Code: Select all
[youtube]n9h34xYsRrI[/youtube]
Enjoy.
Dave L2
Re: New youtube tag
Post by Dave L2 » Wed 25 Jul, 2012 09:39
Thanks Rob.
Re: New youtube tag
Post by pingu » Wed 25 Jul, 2012 11:32
I think that's all mine done. I can't do the ones in the Let's Talk forum (no editing allowed).
Re: New youtube tag
Post by Robert T » Wed 25 Jul, 2012 11:43
Good man, pingu. I have turned editing back on in Let's Talk, so can you give it another try and let me know.
Re: New youtube tag
Post by Brian H » Wed 25 Jul, 2012 19:19
Thanks Robert :)
Re: New youtube tag
Post by Robert T » Sat 13 Apr, 2013 21:29
Quick update - whilst I was fixing tapatalk to display our custom BBCode tags, I found that they already support a simpler youtube tag than the one I had created, so I have now added a new tag that does not need the width and height to be specified, which is hopefully simpler to use. Tapatalk already supports this tag, and with my fix yesterday is now supports our one with width and height as well, so you can use these and they will render in either the normal forum or on Tapatalk.
