Z3 Supercharged
markrnorton
  Other roadster
Post by markrnorton » Sun 25 Jul, 2010 11:36
All clear with the road test, some of the packing did blow out, so its a bit louder at the top end again, but generally in the right direction.
this is the new system at the rear.
and this is the melty pipe at the back !! it gets soooooo hot.
Need to fillet out the rear bumper again then fit the new tail pipe end and mesh out around it, this will prevent anything else melting.
car from the rear now has the right look.
basically there is nothing below the rear bumper line, much cleaner and looks far better.
Two things i have notice with the new exhaust (well re-work 5) is that i can now hear the supercharger alot clearer, wails down the road.
The other thing is that the car is now making 9.9psi of boost against 9.6psi before. I think this exhaust has free'd up a bit of boost power
The saga continues......
Still modifying
markrnorton
  Other roadster
Post by markrnorton » Thu 28 Oct, 2010 17:55
Well, i just realised i never finished off this thread.
Final figure was 230hp from the supercharged M44 at just over 10psi of boost.
A good figure, the car was quick and agile. I reakon with a turbo set-up with the same boost and intercooler it would have made closer to 250hp, as there are no parasitic losses with a turbo. Charge also would have ran cooler/denser with the intercooler. But hey i wouldn't have had all that fun and whining noise (not the other half!)
As some of you would have read, i have now sold the engine/charger etc in foavour of a V8 conversion that will yield a significant increase over the M44.
Still modifying
jont
M44 Supercharger idler pulleys
Post by jont » Tue 20 Sep, 2011 04:12
Mark
Have you had a problem with the idler pulleys chopping out if so what did you replace them with. ?
Regards JohnT
Post by Brian H » Tue 20 Sep, 2011 17:19
jont wrote:Mark
Regards JohnT
John
You might be better to PM Mark as he has now sold (dismantled) his Z, not sure how often he is on here now.
markrnorton
  Other roadster
Post by markrnorton » Mon 17 Oct, 2011 22:07
I'm still about Brian :)
Still modifying
jony9
Re: Z3 Supercharged
Post by jony9 » Wed 04 Feb, 2015 18:49
Hi mate
How's this been running?
I am in the middle of getting some cash together to buy a charger kit for my 1.9 z3.
Any advice would be appreciated.
Thanks jon
Re: Z3 Supercharged
Post by Gazza » Wed 04 Feb, 2015 20:49
Hi Jon, I pointed you toward this thread via FB, just to add that Mark hasn't been on this site since April 2014, you could try sending him an email via this Forum.
markrnorton
  Other roadster
Re: Z3 Supercharged
Post by markrnorton » Tue 10 Feb, 2015 21:31
Hi all, sort of back
Just toying with buying a z4m
Any questions please email, happy to help
Still modifying
