Alarm "HELP" please
webby
Alarm "HELP" please
Post by webby » Wed 07 May, 2014 11:20
My alarm after a few minutes of it being set goes beeb for a few seconds then the hazard lights start to flash but alarm does not go off. Any ideas anyone? All doors and boot are shut properly.
If I lock door manually I don't get this problem. ????????? My car is a z3 3.0i. Reg 2000
henrycrun
Re: Alarm "HELP" please
Post by henrycrun » Wed 07 May, 2014 12:39
Can you describe your fob(s) ?
Post by BladeRunner919 » Wed 07 May, 2014 12:46
It'll be the later alarm, ie not the huge fob.
webby
Post by webby » Wed 07 May, 2014 13:24
It's the one built into the key.
Does that help?
Post by bertiejaffa » Wed 07 May, 2014 14:47
My M has a viper alarm fitted, but I am not sure if or how it is integrated into the OEM one - however it sometimes does the same kind of thing... Everything is shut and locked with the fob but the hazards flash. The fix I use on it is:
Open with the fob
Unlock the boot with the key
Lock the car again with the fob
Dont ask me why, but this works on mine
webby
Post by webby » Wed 07 May, 2014 14:56
Do you need to do that every time?
Post by gookah » Wed 07 May, 2014 16:40
May be the bonnet switch, just try disconnecting it.
Post by bertiejaffa » Wed 07 May, 2014 18:09
webby wrote:Do you need to do that every time?
Only when it happens, usually the fob is fine and works for ages. I dont know why it happens in the first place
gookah wrote:May be the bonnet switch, just try disconnecting it.
bonnet switch??
('_')Z3
Post by ('_')Z3 » Wed 07 May, 2014 19:14
bonnet switch??
As you stand in front of your car it's located above your passenger headlight, it's a bit like a push switch black in colour
webby
Post by webby » Wed 07 May, 2014 19:36
Thanks for help folks. I'm going to tackle the bonnet sensor tomorrow
Post by bertiejaffa » Wed 07 May, 2014 22:13
cool.... whats it do?? The only bonnet switch I know of is the one that opens the bonnet??
('_')Z3
Post by ('_')Z3 » Wed 07 May, 2014 22:16
Presumably stops anyone from lifting the bonnet to tamper with anything without the alarm going off
Post by Robert T » Thu 08 May, 2014 01:23
Interesting, as I have the later alarm on mine and it has never beeped. It either sounds properly or not at all. The LED flashes to indicate a sensor problem. Locking with the key does not set the alarm (the immobiliser is separate and arms itself when the key is removed from the ignition).
You need to check all the sensors. Doors, boot, bonnet switch, stereo anti-theft switch, interior movement sensors, and tilt switch. The latter is in the boot behind the left-hand trim in the bottom of the well - the don't like getting wet.
Jonco
Post by Jonco » Thu 08 May, 2014 09:21
('_')Z3 wrote:
bertiejaffa wrote:
('_')Z3 wrote:
.......... The only bonnet switch I know of is the one that opens the bonnet??
Agree with RobertT's comment - if you are looking at bonnet switch this may help http://www.zroadster.net/forum/viewtopi ... 18&t=15166
