H and R Antiroll bars - Z3M
drummachine
Post by drummachine » Sun 02 Apr, 2017 12:13
Morning Guys :-)
Been looking at this upgrade for a couple of years now.
Reading through many posts and discussions about it its obvious of the plus points but my question was whether it will effect the steering in any way?
Any opinions would be great :)
Re: H and R Antiroll bars - Z3M
Post by Gazza » Sun 02 Apr, 2017 13:12
I have H&R's, no effect on steering but much flatter cornering. :D
drummachine
Post by drummachine » Sun 02 Apr, 2017 13:16
Thanks Gazza
I already have the H and R lowering springs which made a huge difference already. Do you think the roll bars are that noticeable again?
Post by Gazza » Sun 02 Apr, 2017 13:18
I really noticed the difference.
I would set them on the soft setting.
Post by c_w » Sun 02 Apr, 2017 13:24
The H&R bars make a bigger difference than the springs IMO.
Steering is much more responsive and a bit more weighted as you lean on the car in corners. At high speed you have to recalibrate yourself slightly as the car is a lot more responsive.
drummachine
Post by drummachine » Sun 02 Apr, 2017 14:15
You guys definitely arent helping me saving money here :lol:
Post by spurs fan in a coupe » Mon 03 Apr, 2017 05:55
On a slightly different note, are Z3m arbs thicker than 2.8?
Post by c_w » Mon 03 Apr, 2017 16:45
The rear is a little thicker, but the front bar on the Z3M is actually thinner due to the different location it uses on the struts (vs wishbones).
So a standard Z3M rear bar should provide a tiny improvement (but a set of aftermarket will be a better bet!).
Post by spurs fan in a coupe » Mon 03 Apr, 2017 20:40
Thanks Chris
