Z3 Boot Release
stu
  Z3 roadster 2.8 supe
Z3 Boot Release
Post by stu » Sun 22 Feb, 2009 09:38
There's a small part that can fail, which will leave the boot unable to be opened from the outside.
If you have this problem, PM me for the method of boot entry.
Due to the sensitive and security related nature of this fix, it will not be published.
It is requested that the fix is not divulged until we're sure its for a genuine owner with a Z3 boot lock failure!
smartypants
  Other roadster
Post by smartypants » Sun 22 Feb, 2009 10:09
Does this method of opening the boot work even if the car is locked then?
Ballie
Post by Ballie » Sun 22 Feb, 2009 10:55
However, the method mentioned does not take into account the different shape boot of the M roadster.
Im working on a slightly different method for the M. I will PM the moderators with my results. (if it works)
Image Proud to be British!
stu
Post by stu » Sun 22 Feb, 2009 12:24
I believe it works on M cars, Garzza has just been sent the instructions I have and I believe it works if the boot is locked, but again can't confirm 100%.
You'd have to think BMW have to provide a way in without angle grinder/hydraulic rams though, wouldn't you?
Mod Edit - name change
Ballie
Post by Ballie » Sun 22 Feb, 2009 14:29
You would like to think so pal. Ah, i see. So the boot is the same shape as the 2.8. Ill have to be carefull not to mess this up. Ill attempt it next weekend.
