Our search engine is not very bright and when searching for common terms it will return lots of useless threads. Besides using Michael Googlee with site:zroadster.net, the other way to find threads easily is to use obscure search terms. So here is the challenge, can you come up with search terms that just return a couple of useful threads. Here's a couple to get you started:
impregnating - for threads on re-waterproofing roofs
nephew and hole - for threads on removing the headlight switch
housebrick - for threads on the earlier type of Z3 alarm
So can you come up with any more obscure than mine?
The ZRoadster Search Engine
Re: The ZRoadster Search Engine
As you've already cited my nephew hole solution, how aboutRobert T wrote: nephew and hole - for threads on removing the headlight switch
cat and blanket - to protect you rear screen and hood ?
Would probably make sense to petition the mods/site owner to upgrade to the latest version of the forum software (phpBB). Looking at the list of improvements between 2.x and 3.x, search has been updated somewhat!
As per OPs reference to Google - if you put the following in to google you may get some better results than the native search...
site:zroadster.net required search term
Gaz
Gaz
BMW Z3 2.0 Titan Silver - Progress Thread
(Pictures - http://s852.photobucket.com/home/gazhyde/allalbums)
