Advanced Search - HELP!!!
Advice and assistance on computer matters
DomS
Post by DomS » Thu 13 Mar, 2014 16:57
How on Earth do you do an "Advanced Search" on this (or ANY!) forum???
I want to search for a string/phrase (e.g. "ABS wiring diagram").
I don't want posts that have ABS and wiring and diagram scattered around as individual words.
I DO want posts that have the string or phrase ABS wiring diagram.
If I enter the search string in quotes as above, I get results for individual words.
If I enter the search string with "AND" between each word, I get results for individual words.
If I enter the search string with "+" between each word, I get results for individual words.
I can't believe it's not possible to search for a string/phrase, or is it really not possible???
I can't find help anywhere (either here or anywhere on Google) that can help! :bawl:
Any help appreciated (including links to the pinout of the ABS control module :) )
Cheers,
Dom
Re: Advanced Search - HELP!!!
Post by Brian H » Thu 13 Mar, 2014 17:54
^^^ Dont know, but if you are looking for the wiring diagram for the ABS circuit you will need the Electrical Troubleshooting Manual (ETM) which can be found here > Clicky Link
The link will automatically start to download the ETM PDF.
HTH
Post by Robert T » Thu 13 Mar, 2014 18:43
Site search (even advanced) is a bit basic with phpBB. If you want to do a more advanced search, enter the following into Google:
Code: Select all
site:zroadster.net "ABS Wiring Diagram"
However, it would appear that this is a bit of a Googlewhack, returning just this thread!
If you drop the "ABS", and just search for "Wiring Diagram", you get 1,310 results, most of which look useful.
A full set of links is actually given in the knowledgebase, here: http://www.zroadster.net/forum/viewtopi ... 18&t=34176
DomS
Post by DomS » Thu 13 Mar, 2014 19:12
Brian/Robert,
Thanks very much, both very useful links.
I always try and search for answers before posting a question and I thought I must be doing something a bit daft when I couldn't search for a complete phrase (to avoid sifting through what could be 100's or 1000's of irrelevant results) ...but hey ho, it looks like I can save my :dunce: cap for another day!
Cheers,
Dom
