Dear All
I am in Bahrain and need a door belt and two rear brake discs (second hand would do)
Are the rear brake discs the same as anything else or unique?
I am coming to London on Friday and need to sort it out - any advice on where i can get these parts would be much appreciated.
John
rear brake Discs and door belt needed - advice required
Bitz for Z1
Hi John, I'm nearly certain the discs are unique to a Z1. The front are standard. The belt is a bit unusual also (about £30).That would also have to be ordered through BMw. i'd order the parts over the phone now throught a bm dealer with visa. The parts come from a slightly different section of the bm network and unless in stock will take a bit longer to get. When do you go back?Hope this helps. Nik
