I need help to adjust the front cover of my z1
bmwz1971
  Z1 roadster
Post by bmwz1971 »
I need help,
Who can tell me how to adjust the front cover of my Z.
I have a 5 mm space above my left headlight.
Thank you in advance for your help.
TdO
Here is the picture
http://s157.photobucket.com/user/bmwz19 ... a.gif.html
fluoman
  Z1 roadster
Re: I need help to adjust the front cover of my z1
Post by fluoman »
If the front bumper is correctly aligned with the engine hood,
you need to lift up the headlight. (4 screws fixing).
After you must adjust the beam.
@s@P fluo
Jet
Post by Jet »
What happened beforehand, was the bonnet removed for some reason? Accident repair?
bmwz1971
  Z1 roadster
Post by bmwz1971 »
I bought the vehicle there one year. the problem was already present. I think it is a bad setting. I'll look for the headlights. thank you for help
bmwz1971
  Z1 roadster
Post by bmwz1971 »
Hello fluoman,
can you show me where are thoses 4 screws?
I'll try to adjust it this weekend.
thank you in advance
Tanguy
fluoman
  Z1 roadster
Post by fluoman »
Hi Tanguy,
@S@P fluo
Jet
Post by Jet »
fluoman wrote: you need to lift up the headlight. (4 screws fixing).
@s@P fluo
Hey Fluo,
Its 5 screws, dont forget one underneath. Gently lift the indicator unit and a 10mm spanner, or from under car with undertray off.
When we going to have that talk? Send me a PM.
fluoman
  Z1 roadster
Post by fluoman »
Hi Jet,
No, it's 4.
Perhaps you have 5 on your prototype (or in yours dreams) :wink:
5 studs wheels, yes, ... sometimes with big wheels!
Here is yet another proof, from marco website.
http://www.microsofttranslator.com/bv.a ... heinw.html
The fourth is the most difficult of access.
In french, we said "Jet does not exceed the master!" :wink:
@S@P fluo
Jet
Post by Jet »
Indeed it is 4, the one underneath being the 4th. Your diagram is a little confusing, the 4th arrow should be pointing up, not downwards.
Must be a French thing :)
Post by pingu »
I don't think the problem is with your lights. I think your bonnet is "on the pi$$".
From what I remember of looking at the front of a Z1 at Silverstone, there is a plastic bush in the hinges of item 14. If this deteriorates and the bonnet is realigned with the broken hinge in place, you will have your symptoms...
If that is the problem, I don't think they are available as a BMW spare, but others have sorted the problem, so the solution is out there.
