Z1 doorswitch inside
Cabrioot
  Z1 roadster
Post by Cabrioot » Thu 09 Jul, 2015 14:22
Z1 The doorswitchlever on the inside will not return :head:
The covver that keeps the spring is broken and can not repair this from the inside
Someone now how to reach it.
Do i have to take the door out or just the pannel underneat the door.
:rtm: :rtm:
Jet
Re: Z1 doorswitch inside
Post by Jet » Thu 09 Jul, 2015 17:20
Just so I understand, the inside pull lever is stuck? The part that broke is the square cover that fits around the handle? If the problem is inside the car, you dont need to remove the door for that.
Cabrioot
  Z1 roadster
Post by Cabrioot » Thu 09 Jul, 2015 23:18
The doorhandel is returning by a smal spring.
The spring is held by the plastic cover inside the door.
The plastic cover is broken so the spring in not held anymore
Question is can the doorhandel mechanisme be removed frome the inside or the outside of the frame.
Jet
Post by Jet » Fri 10 Jul, 2015 15:51
the entire Inner door handle mechanism is held on with 2 screws, remove those, disconnect connecting rod, replace with a new unit and refit.
Reattaching the connecting rod to the handle needs some twisting, but it's relatively simple to do.
Cabrioot
  Z1 roadster
Post by Cabrioot » Fri 10 Jul, 2015 21:00
Thanks, will try but at this moment no time
Will let you now when :)
Cabrioot
  Z1 roadster
Post by Cabrioot » Tue 14 Jul, 2015 13:11
Thanks problem solved.
Very aesy job stupid from me to wait 5 years with repair.
Practice is much easyer than in mine mind
Thans again
