Steering Rack Compatability
sfh3l
  Z1 roadster
Post by sfh3l » Fri 05 Feb, 2016 17:43
Hi Guys,
I can't help thinking that I should know this already, but can someone tell me if an E30 M3 steering rack is a straight replacement for the Z1 (obviously higher geared), as in will it fit to the front subframe without any cutting, welding and general mashing about?
Just an idea I have in mind :D
Thanks in advance.
Best regards,
Sam Lever.
My Financial Blog
Re: Steering Rack Compatability
Post by c_w » Fri 05 Feb, 2016 19:35
Not sure why you'd want one of those, but isn't the Z1 more E36 tech? They all fit each other though E30/E36/E46, the latter have much nicer ratios to quicken the steering up.
Pat Slade
  Z1 roadster
Post by Pat Slade » Sat 06 Feb, 2016 07:04
Hi Sam,
The answer is yes. But E36 item would probably do the trick for less cash and more readily available.
As your other respondent says I think the E46 rack will also fit. My understanding is the only other parts that might need changing are the rack feed pipes.
Pat
senna
  Z1 roadster
Post by senna » Sat 06 Feb, 2016 14:08
Yes it is a direct swap
No modifications needed.
I have done this three times.
Engine Transplants by Night, Heart Transplants by Day. "you own the best Z1 in the world"
