Is it possible to detach the rollbar from the windshield? Can this be done DIY or requires specialist?
Rgds
J
PS: Rollbar = curved bar at top of Windshield, sun guard is attached to.[/b]
Rollbar removal
Rollbar removal
- Paul Drawmer
- Z Register member
- Contact:
Apart from; why on earth would you want to do that?
The roll bar is an integral part of the chassis. It is welded to the top of the 'A' pillars, which are in turn fed down into the base frame as far as the wheel arches. This is to provide real roll over protection.
If you look at the 'construction' pages at:
http://www.bmwz1.co.uk
you will see a couple of pictures of a Z1 'undressed' that show the roll over bar.
Hi Jet,
You must be MAD thinking of removing the roll bar!
As Paul says, it's integral to the chassis design (I actually thought the bar itself was one unit all the way down to the wheel arches, with the 'a' pillar panels and windscreen surround welded to it?)
To remove it you would encounter the following problems:
Big loss in structural rigidity - the roll bar not only acts as roll-over protection, but also chassis strengthening (like a roof does on a normal car!) so removing it will mean your car will start to wobble and shake and fall apart due to it not being held together properly!
Insurance; try and find an insurance company that will cover you for removing the bar - they just won't without giving you a CRAZY premium. If you don't tell them, your insurance will be invalid becuase you have changed one of the structural elements of the car.
The best way to look at it - would you remove an RSJ from your house because you thought it would look better for it? How long will your house be standing if you did??
Going back to Paul's original question - WHY???
Regards,
Bruce.
Regards,
Bruce.
