I was out driving in the Zed (3.0) on Tuesday when I experienced a strange problem with the engine. I was driving up a familiar hill that allows me to really open up the engine. I went to maximum revs in 2nd gear then changed to 3rd and went close to maximum again.
The engine appeared to reach cutout on the rev counter and that is when the problem occurred. The engine then seemed to lose power and started sounding really rough, as if not firing on all cylinders. the loss of power continued as I "limped" home not wishing to cause any further problems.
When I got home I lifted the bonnet but could not see or hear anything untoward. I left the car overnight and took it out for a run again last night to see if the problem has got worse/better.
Here's the really strange thing, she ran perfectly with absolutely no sign of a problem.
Has anyone experienced this sort of thing before and does anybody have any idea what caused the engine problems I experienced?
Has anyone had this problem?
- Bob Hoskins
Yup, I have had this problem. Unfortunately for me it was related to a aftermarket traction control kit, short story, i eventually had all my coils replaced as when the computer was put on the car at the garage it said coil pack 5 was failing. It eventually transpired that the old coil oacks were fine because the problem was still there with new coil packs fitted. I disconencted the traction control and this solved the problem.
When yours felt like it wasn't firing on all cylinders it should have saved the error code of what failed. If you take the car to a garage they can run the diagnostics and tell you where it went wrong. As Freezed said though, it sounds like you have hit the rev-limiter and the car has stayed in "limp home " mode. As with my problem above, when mine wasn't firing on all six, it was after being on the Aston Martin test track at Gaydon. First it felt like it was firing on only 5 and then later on, only 4. This was on my 100 mile journey home. I stopped to get fuel and suddenly it felt ok again. A change of coil packs and disconnecting the TC and never had a re-occurrence.
Tags
Tags
Sorry Bob, but if you deliberately hit the limiter every time you change gear, you're going to get problems.
The limiter is there to protect the engine from driver mistakes, not as a signal for you to shift up.
Sounds like coils as mentioned, but the number of times you hit the limiter is (I believe) stored in the ECU and such severe and frequent thrashing could quite possibly trigger the 'just get home' safe mode.
A.
A.
- Z Register member
Coils as stated, but you should try not to rake the engine as much.
smartypants wrote:Conor?
With an M??
The World's gone mad
