is it a single or dual vanos ???
Adam
Post by Adam »
I'm biting the bullet and going for the BBTB & Manifold kit for the zed.
I just want to confirm though that my car is a single vanos as the kit wont work with a dual vanos.
The build date on the car says JUL 1998
Its a 98 s reg 2.8
if its the single (which i think it is) then the cheque is going to ian for the bits....and then I can have some fun.
estocks
  Not specified
Post by estocks »
Single Vanos. DV came with the M52TU engine in 1999.
Adam
Post by Adam »
thanks...thought so.....
can i now blame you for the dent in my bank balance after I buy the kit as you confirmed I have single vanos :D :wink:
risquenun
Post by risquenun »
Don't be so sure it is single Vanos. my orinoco with an Oct 98 build date has the twin vanos engine!!
This Orinoco doesn't Womble.
phb10186
Post by phb10186 »
Where do you find the build date and engine code, its not on my V5
Real OEM shows a build date for me of 10/98.
I was under the impression that I had a DV engine
Please don't tell me Wikipedia!
1998 2.8 M52TU, pre-facelift, hard top, montreal blue, tan interior, 91K
phb10186 wrote:Where do you find the build date and engine code, its not on my V5
On a sticker on one of the suspension strut towers under the bonnet. :wink:
RealOEM should show also you your engine designation if you enter the last 7 digits of your VIN.
phb10186
Post by phb10186 »
risquenun wrote:Don't be so sure it is single Vanos. my orinoco with an Oct 98 build date has the twin vanos engine!!
I have got an October 1998 biuld date as well???
Double Vanos? - Single Vanos... How can I be sure?
Is there anything on the engine itself that is distinctive?
real OEM gives this info:
'P Z3 roa Z3 2.8 M52 ECE 19981000 R N'
mich
Post by mich »
Have a look at the Engine :o at the front of the inlet camshaft [at the front of the engine] you will see an aluminium housing, go down and to the left a bit to where the Exh camshaft is and there you should see another housing, just the same.
so 2 hsgs = twin. 1 hsg = single :) :)
"X" = Inlet Hsg. Exh is down and to the left. this is a 2002, 3L but 2.8L should be the same as far as I know, hope it sheds some light on the mystery
phb10186
Post by phb10186 »
I can see 2 housings, the seccond one you refer to is about 3 inches down and to the left... there appears to be a couple of bolt heads on the front facing side of this lower housing that you describe.
I havnt seen both types, so it is not immediately apparent.
mich
Post by mich »
Yes that is the one phb, on the pic below you can make out the 2 studs with the nuts on them, you will also see a couple of electrical leads coming from the unit, I know it needs a bit of a clean, aluminium castings are a s*d for oxidation :)
phb10186
Post by phb10186 »
Ok so I guess I habe a double Vanos engine... must have come in during October 1998 then.
