Just been to a breakers for a boot lid... problem...
The wiring to the third brake light and boot lock which goes through the lid doesn't seem to simply unplug. The only way of removing seems to be to cut the wires to the main loom. I don't fancy doing any splicing any suggestions???
Anthony
Z3 Boot Lid
It would be best to cut it somwhere inside the boot and then just use insulated inline bullet type crimps from Maplin or RS, leave your self as much spare cable as you can when you cut.
BMW do a repair loom as this cable is prone to breaking at the hinge point but it is expensive and appears to have crimps to join it to the main loom.
See here part 1:
http://www.realoem.com/bmw/showparts.do ... g=61&fg=10
Crimps
http://www.maplin.co.uk/Search.aspx?cri ... &source=15
Ade
See here part 1:
Crimps
Ade
why won't it pull through?? Is it due to connectors?? Most should have demountable pins so you can remove the connector just make sur you make colour and pin location to put it all back.
I may be wrong but if it doesn't fit the connectors where fitted after the wiring was put through this must be able to be reversed???
Looking at the oem bmw pic it should unplug. Maybe will have to remove the third brake light. feeding the wiring back through for the new boot may be a pain tho.
Anways the boot at the breakers is scratched a fair bit and dinted so would need a re-spray...
Any one got a topaz blue boot in good nick? LOL
Anthony
Anthony
do the wires sereously not unplug from the boot lid?.... are these deliberate design flaws simply to generate workshop time???
-Why do I keep answering my own questions?, of course they are.
There are lots of things like this on BMW's for some reason.
1998 2.8 M52TU, pre-facelift, hard top, montreal blue, tan interior, 91K
