engine problem
dansutton
engine problem
Post by dansutton » Sun 05 Jul, 2009 15:38
hi all
i've got a 97' z3 2.8 and at the front on the car under the radiator are two rubber pipes that then attach to a metal square shape pipe which has started to rust. Any ideas as to what the metal pipe is? And are they expensive to renew?
Thanks Danny.
estocks
  Not specified
Post by estocks » Sun 05 Jul, 2009 15:46
They all rust there.
Mike Fishwick
Diy
Post by Mike Fishwick » Sun 05 Jul, 2009 19:16
If you try following the rubber pipes, you will see where they go . . .
John Boy
Post by John Boy » Sun 05 Jul, 2009 19:54
Part of the power steering i believe (cooling pipe), PART 9 HERE
Edit to add that I think they are around 60ish quid from the dealer.
John Boy
2.8 Z3
Mike Fishwick
Rust
Post by Mike Fishwick » Mon 06 Jul, 2009 08:58
Why do you want to replace the pipe because it has begun to rust?
Scrape any loose rust off, treat it with a rust remover such as Jenolite, and paint it with Finnegans Red Oxide Primer followed by a few coats of their satin black.
All people can think of these days is fitting new bits, rather than doing something themselves. I painted mine about eight years ago, and it's still fine. The steering rack plating also goes off quickly, but decent paint lasts for ages.
stu
  Z3 roadster 2.8 supe
Post by stu » Mon 06 Jul, 2009 20:49
If it's the power steering pipe, then they do fail on Z3's, as I know. If it is, I'd recommend a replacement be fitted. They're not cheap though.
A picture speaks a thousand words with problems like this though, so if you post one, someone will know.
You could also have a look on Realoem.com for the bit.
John Boy
Post by John Boy » Mon 06 Jul, 2009 21:11
stu wrote:You could also have a look on Realoem.com for the bit.
See the Link in my post above :wink:
John Boy
2.8 Z3
dansutton
Post by dansutton » Mon 06 Jul, 2009 23:23
been to local indy today, and he suggested treating the rust 1st as it is £170+vat just for part then fitting. Thanks for everyones help on this one
John Boy
Post by John Boy » Tue 07 Jul, 2009 10:03
I would get a new indi! I just got a quote for £61.82 inc Vat from Soper BMW...
John Boy
2.8 Z3
John Boy
Post by John Boy » Tue 07 Jul, 2009 18:58
I can only hope that your indi has quoted for the wrong part or I have mistaken which part you mean as a mark up of more than 3 times is daylight robbery in my mind! :evil:
John Boy
2.8 Z3
John Boy
Post by John Boy » Tue 07 Jul, 2009 19:00
double post due to dodgy connection
John Boy
2.8 Z3
Mike Fishwick
Painted
Post by Mike Fishwick » Wed 08 Jul, 2009 14:03
Don't be afraid of a bit of rust - the PAS pipe is quite thick.
My PAS pipe was covered in rust when I bought the car at 13,000 miles, due to the epoxy coating on it having cracked and flaked off.
This was due to the absence of a bolt to secure the lug on the pipe to the steering rack, allowing the pipe to vibrate.
I fitted a new bolt, wire-brushed the pipe, treated it with rust remover, then primed it with Finnegans Red Oxide primer, and gave it a few coats of their satin black.
It's still as good as in this picture.
