Brake lights have failed but boot mounted brake light still works. I'm going to check the bulbs but strange if both have blown at once. Could it be the switch or a fuse? Is switch an easy fix?
Thanks for any advice.
Rayboy
brake lights
Brake Lights
As a new owner myself, I don't have any specific Z brake light knowledge but as with any car you need to firstly check the bulbs - as you've already concluded - and then try to trace the supply cables back to where they part from the supply to the high level light. Two possibilities are: a common cable to the lower ones being damaged after the split from the high level light, or a loss of the earth return from the housings to the chassis/body. It is possible that there is a separate fuse to the HL light to ensure some sort of brake light works in all conditions. Look at the fuse box too. A cheap meter would help; look at Maplins. Good Luck! ...let us know what you find.
