Having issues adding this to my other post so sorry for the new post!!
What do you all think? my Z3M transformation is coming along well!
Quad Custom 'M' exhaust fitted to Z3 2.8 *pictures added*
Hello - no they are not just cosmetic.
There is a second pipe that runs from the back of the backbox with a pipe that had to be shaped underneath the car and then connected to the outlet. To have this set-up the spare wheel + bracket have to be removed.
As it's all 'one off' brackets were made (rubber mounted for flex) and welded to appropriate mounting areas under the car. I will take some more shots from under the car to show you better.
Regards,
Adam
Regards,
Adam
*please quote my name (Adam Hicks - Silver Z3 2.8) when you call so you get this price*
£500 fitted including everything.
http://www.mijperformance.com/contact.html (Birmingham)
It sounds awesome, I went for the 'mid sport' backbox which gives a lovely roar but not to loud so you can use the car everyday without your ears bleeding!
Cheers,
Adam
Cheers,
Adam
Lucky
Do you feel lucky? I hope you don't have a puncture, or at least have your tyres treated with Puncturesafe.
