Am I the only one?
Am I the only one?
In order to mitigate getting rear ended, I always drive with my rear fogs on.
The lights are bright, and as there are two, it looks OK (ie not asymmetric)
Am I the only one?
Am I the only one?
"The law, as presented by The Highway Code, states that front and rear fog lights must not be used unless visibility is seriously reduced - which generally means when you cannot see further than 100 metres (328 feet) - and that they must be switched off once the visibility improves."
You might want to stop doing that
edit: just realised you're not in the UK. I'd still stop doing it as it's really irritating driving behind someone and being dazzled by their fog lights.
No, unfortunately!
Is this a p*ss take? I thought it was only Micras and Volvos!
You are causing nuisance and inconvenience to other road users by doing so, particularly with reflective road surfaces after rain, and at night, and increasing the risk of being rear ended as your brake lights will be less obvious.
Please either switch them off, or trade in the Z.
Re: Am I the only one?
I hope so!!!BonBon wrote:In order to mitigate getting rear ended, I always drive with my rear fogs on.
The lights are very bright, and as there are two, it looks OK (ie not asymmetric)
Am I the only one?
IMHO high intensity rear fog lamps are overused. I understand their purpose when the weather conditions are severe enough to warrant their use, but at the first sign of slight mist, some drivers feel the need to switch them on and I find them a source of distraction and annoyance.
Forum members have commented in the past about the misuse of front fog lamps, but given that they should be aimed low with their light spread immediately in front of the car, I find them significantly less distracting than the rears.
Skoda Octavia vRS TSi DSG on Tour at Rocamadour
What a flood of emotion!!!
This will surely bring the best out of Mike.
BTW - There is (perhaps was) an additional reason - I always drive with my lights on - and during the day there is no indication on the panel that the lights are on...... more convenient than looking closely at the headlight switch.
- markrnorton
Turn them off quick before Mike finds outBonBon wrote:What a flood of emotion!!!
Still modifying
One of my pet hates, its not only inconsiderate but dangerous, especially at night, there must be something about drivers in the UK who think its normal to switch front fogs on and use them as driving lights in clear conditions, thick comes to mind Even worse using rears in daylight as it can be hard to tell if a vehicle is braking at times. Its just common sense which is lacking for many.
Please "spell-out" the reference to Volvo drivers.
Did I miss a crucial episode of "Top Gear"?
Here in the winter (November-April) headlights must always be on. Due to the dreary conditions in the UK, I'm surprised that lights are not imposed all year round - especially dangerous are the "tree-rich' side roads.
(there is a high percentage of local drivers who think tailgating is an Olympic sport - so if some a**hole thinks my brakes are on - all the better. When I really brake I have the additional pair and the third brake light)
I thought everybody knew that rear fog-lights are switched on in September and off in June. That's according to the knob head's handbook, just below the section on never using your indicators unless you're parked half on the pavement and half on the road in which case they may be used in "hazard" mode as magic parking lamps.
BonBon wrote:Aren't all Z3 drivers, who use a classic phallic symbol as a mode of transportation, knobs?
HT
HT
Titan's apprentice.
Titan's apprentice.
Official Devil's Advocate
Leg Puller
Micky Taker
rear fog lights
I bet you also pull up to the lights in the right hand lane, then just as they turn green you indicate to turn right! grrrrrrrrrrr
I wish you were the only one.BonBon wrote:Am I the only one?
You've got to be a proper idiot to think that's a good idea in anything other than foggy conditions, I mean - why else would they call them FOG lights?
Dear god, let this be a wind up... if you want to "mitigate" the chances of getting rear ended, paint it up like a police car or wrap it up in bubble wrap or even park it in a garage and never let it see the light of day...
(actually I've been playing golf at Celtic Manor for 2 days before the Ryder cup starts )Mike123 wrote:Jonttt - is this you pretending to be a complete tw*t from Israel for a laugh?
I think this is a classic case of cultural differences.
Bonbon has no real way of knowing what a big issue this is in the UK
It was "misty" in Wales on Friday morning when I arrived at Celtic Manor and the number of cars driving around on Saturday night with their fog lights on was laughable ie they had turned them on on Friday morning and forgotten to turn them off, always the same for days after a foggy day
Front foglights on all the time has always been a problem in the UK but no so much the rears in my experience.
I used to have fun with my scoobies fitted with full driving lights, I'd drop behind a car with their fog lights on an turn on the driving lights to see how they liked to really be dazzled
The new LED "running" lights started by Audi seem to have only made things worse as manufacturers now seem to be having a competition to see how can make the brightest, I was followed by a "60" plate VXR Astra yesturday and could not believe how bright the running lights were in full daylight, they would be frieghtening at night!
Anyway I think the answer to the OP's original question is that its not a good idea to run with any fog lights on in anything other that very poor visability as it is just dangerous to other road users and one of the most selfish acts I can think of in a car (ie I'm alright and sod everyone else).
I've been followed by Audi's with these a couple of times now.Jonttt wrote:The new LED "running" lights started by Audi seem to have only made things worse as manufacturers now seem to be having a competition to see how can make the brightest
Have you noticed that they automatically dim when the indicators are used, presumably because they obscure the front indicator from being seen.
BMW Z3 2.0 Titan Silver - Progress Thread
(Pictures - http://s852.photobucket.com/home/gazhyde/allalbums)
I'm contemplating a set of LED sidelights for the frog - the indicators double as side-lights and I have seen some LED lights that have both yellow and white LEDs in them - they are white when in sidelight mode, then when you turn the indicator on, the sidelight part goes off and it flashes yellow until you turn the indicator off again - I thought these would be safer than just having the bulb flash brighter with a second filament.Gazhyde wrote:Have you noticed that they automatically dim when the indicators are used, presumably because they obscure the front indicator from being seen.
I drive around with my front fogs on, but only when my both my headlights bulbs have blown.
I'd like one of those LED scrolling signs - in the UK I would only need two messages - "turn your sodding foglights off" and "use the bloody handbrake" - the latter for my other pet hate of people who sit with their foot on the footbrake at traffic lights in the dark - absolutely ruins your night vision if you are sat behind them in a low car.
Fog lights on when not needed are a pain in the butt.
So too are HID's even when they are needed at night.
Way OTT in dazzle to other oncoming drivers.
I'm surprised they're legal.
Anyone that can't see well enough at night with mere halogen headlights shouldn't be driving.
'High G' motoring enthusiast
Could it be that they are a little unhappy that you have your fog lights on - do they flash their full beam at you as well?BonBon wrote: there is a high percentage of local drivers who think tailgating is an Olympic sport
If someone rear-ends you, it's probably because they're texting with their mobile or have fallen asleep etc. Either way, they're generally in the wrong for not allowing sufficient braking distance (not to mention texting or sleeping etc!).
By having your rear foglights on, you not only irritate all the good drivers, but you also give a potential rear-end shunter an opportunity to try and shift the blame "I came round the bend and was blinded by those rear foglights"!
If it's not foggy, turn them off ...there's a good chap.
Now that everyone had the opportunity to gang up on me - I thought I'd have another critical look at the rear fogs:
During the day, it is so bright here, there is no real difference.
At night the fogs are also not much brighter than the rear lights. But.... one of my rear fogs is less bright than the other - so it appears that either the bulb(s) is/are covered in soot or the lenses have a thin layer of dust on the inside.
Nevertheless, to comply with the emotion displayed here (and an obvious pet peeve in the UK) I will comply with forum's overwhelming recommendation.
I'll clean out the lenses/bulbs and NOT turn on the rear fogs unless the conditions are poor.
I will sorely miss a dash indication that the lights are on during the day.
........and my Dad always told me that "You can't teach an old dog new tricks"
Well said BonBon!
Welcome back!
