I have a few annoying small problems which I would like to sort.
Firstly, when I use the fan inside the car it blows in smalls bits of leaves etc. Is there a filter in which I can check?
Secondly, how do you adjust the hood seals around the top of the doors. Passengers door is fine but im getting a lot of wind noise from the drivers side. Do the adjustments have to be made to the door position or to the hood itself?
