Abs pump
Abs pump
Can anyone help I have had the abs /acs lights on for months
not worried about it as brakes work fine.
I have change the front sensors as the old ones i had to drill out they would`t budge, I manage to get the rear ones out and cleaned them ,the
lights still on after a week.Should i now be thinking of changing the pump?
If so the oem part number 34511164333 is not the same as the one on the
car which is 34511164896 also i have found one 34512229827 which comes up as one for an z3m would this work ?
My car is a jan 99 1.9 z3 can anyone help please
That's a good suggestion as there are many other factors which could cause the ASC/ABS light to illuminate.
The sensors are (generally) the primary culprits, but they rely on a trigger signal from the hub.
I understand that these can lose their castellations thereby giving an unexpected signal which materialises as a warning light.
Do remember that although your brakes will continue to work, you will not have any ABS or ASC - ie just like cars used to be
- markrnorton
Abs pump
Thankyou for all your input , Hopefully I will be getting to borrow a
code reader soon will post up any findings
Abs pump
Right had the fault codes read using a u480 memo scanner
came up with p0100 Maf A circuit malfunction
p0130 o2 sensor circuit malfunction(bank 1 sensor 1)
p0135o2 sensor heater circuit malfunction (bank 1 sensor 1 )
No faults on the abs/acs yet dash lights still on
With regards to the faults above I have read on the forum you can clean the maf sensor with carb cleaner can you clean the lambda sensor or is it bight the bullet and get a new one
Next thing on the abs/acs lights is to check the switch
any help greatly appriciated
Went through same as you with my z3,had same probs removing front sensors with great difficulty. Removing and renewing both to no avail.
Checked rears (having cleaned both)and found one was open circuit whilst the other one measured 1028 ohms.
save yourself further grief and fit new rears.
Mine came off eBAY No.31302608757 at around£36 the pair or alternatively,buy one and try on both sides.
P.S. mine is same year as yours and at 51k had already had one rear sensor replaced by stealer,as luck would have it,it was the origonal
that let me down.
that let me down.
Abs pump
Have at last solved the issue changed the abs unit all sorted
Bought one off ebay at good price ,straight swap over
even drives better i think that the old unit was stuck on
