Have done a search, as well as looking in the knowledge base, but have not found an answer to my question .. so here goes ..
When locking/unlocking the car via the key fob, all is ok - that is, the car locks/unlocks as expected. But only when I lock do the lights flash. Is this normal? If not is it an easy fix? Thanks.
Hi Vince, my indicators only flash when I lock - not when I unlock, I think it's more a security thing so that if you are being followed no-one would know what car you are approaching - apart from mine makes a quite a racket when it unlocks and draws enough attention to itself!
On the later alarm the indicators only flash on locking and not unlocking. This is as stated to avoid attracting attention in a car park. In a dark car park, the third button can be used to turn on the interior light (assuming you have it in the door activated position). If the indicators do flash when you unlock the car, it means that the alarm has been triggered since it was locked.
