Rear wheels wearing out too quick
- chris1984_99_99
Hi guys, I did a search and couldnt find anything really aobut this subject.
I changed all 4 tyres less than 5000 miles ago, the rear wheels are already almost bald on the inside. When I was getting them put on the car the guy said the cambre didnt seem right, so I went to a mechanic who apparently adjusted it, but the problem still seems to be there, if not even worse. Theyre wearing out far too quick on the inside and almost untouched on the outside!
Has anyone ever had this problem before? If so how did you get it sorted? (PS Im the least technical person there is, so dont ask about what type of tyres I have fitted, theyre nothing fancy by any standard!)
Cheers guys!
Chris
Cheers guys!
Chris
Put some tyres on them.
HT
Titan's apprentice.
Titan's apprentice.
Official Devil's Advocate
Leg Puller
Micky Taker
- chris1984_99_99
You have also got 18" wheels which will have stiffer sidewalls due to the reduced profile which will exaggerate the wear the inside more if you have any camber on the rear.
Aceman
Arctic Silver '98 Z3M
Previously;
Bright RED '99 Z3 2.8
Previously;
- RemarkLima
Still, with all that in mind, the tyres should still last more than 5000 miles surely?
I'd also get the toe checked on the rear, as too much toe in or out will cause very rapid wear on the tyre (basically, it's moving at an angle compared to the direction of travel), and with the -ve camber it'll exacerbate the problem.
Any tyre shop should be able to do toe alignment easily enough.
- RemarkLima
You say they are bald on the inside, but what are they like in the middle and outer edge? If the outer edge is 4mm or below then it's probably OK. If there is a wild difference then get an alignment check done to see how far out of spec it is.
As has been said, adjustment for toe is only via eccentric bushes or a weld in option. Camber can be adjusted with and eccentric bush or by changing the thickness of the spring pads.
Do you do a lot of motorway driving?
I imagine a squarer shouldered tyre will wear more that a rounded shoulder, on mine you can see the rear wheels splayed out when viewed from the rear but don't seem to suffer any undue wear.
Not sure what tyres you have fitted but might be worth trying a pair of Michelins as they tend to be harder wearing, when I changed the alloys and took the Michelin PS3 off there was no inside shoulder wear on them.
