Hi!
Last week I put the CD magazine into the unit in the boot and the player showed 'No CD'. I tried to eject the magazine, but nada!
After a bit of trawling around the forums I found a solution which may be of use to someone in future.
I slid an old credit card under the CD unit from left to right and it 'caught' on a manual release trigger under the unit, flicking it and ejecting the magazine. With the CD magazine out I then pressed the eject button and let it reset. I then put in the magazine - gently - and it worked fine.
This has happened again once since and the card 'trick' worked.
Hopefully, this will be of use to anyone experiencing the same frustration.
Gelert.
CD changer was stuck but managed to fix - May help someone.
Miss Sexy-Hips .... 2002, 2.2i Sport Roadster, Titanium Silver
A brief search on here for "CD and stuck" reveals 18 threads on the subject. It is something that seems to happen to somebody about every 4 months.
Start here:
http://www.zroadster.net/forum/viewtopic.php?t=25964
and here:
http://www.zroadster.net/forum/viewtopic.php?t=25847
It ought to be in the knowledgebase - maybe you could take some pics and write it up?
Start here:
and here:
