hard top advice
davetook71
hard top advice
Post by davetook71 »
I am looking to get a hard top for the z3 and have an opportunity to get one plus the fitting kit. What I need to know is how hard is it and how long does it take to get the kit off the donor car and on to mine? Is there a post on the forum covering this as I have looked to no avail.
Second question is how much to get a decent paint job done on the roof.
Finally should I be looking to replace any rubbers on the top before fitting.
Dave
aceman
Post by aceman »
The basic fitting kit can be transferred in about half an hour with the heated rear switch taking maybe an hour later on taking your time. A respray shouldn't be a problem for a good bodyshop making sure they remove all the seals but you could save some time and money and strip it yourself. Expect to pay upto £200 for a good spray job and yes depending on the condition of the seals you may want to replace them but if the hardtop has been reasonably well looked after you may not need to but there are some rubber pads that sit at the back and rest on the bodywork which I would recommend replacing no matter what as these do go hard and flat after a while, only a couple of quid each so not a major expence and worth doing.
Is it the one on ebay going for £650 with the fitting kit, if so it's not a bad price really to say everything is there to get the job done as fitting kits can be a nightmare to source if you want originality.
Forgot to say you will have to fine tune the fitment of the brackets to get the hardtop sitting right but I have full fitting instructions somewhere as do others so you only need to ask and we can provide all the info you need. :wink:
Aceman
Arctic Silver '98 Z3M
Previously;
Bright RED '99 Z3 2.8
davetook71
Hi Aceman,
Tks. for that. I can't see that one on ebay for £650 can you send a link or tell me what search criteria you are using?
Dave
aceman
Post by aceman »
It was this one which was on over the weekend but looks like it has sold I am afraid. :(
http://www.ebay.co.uk/itm/BMW-Z3-Hard-T ... 4ab080c307
Aceman
Previously;
