Do our zeds rust?
Do our zeds rust?
As ive never really come across a thread on here bout rust i was wondering is there any places on the zed that can be prone to rust?
I ask because im thinking of taking my sills off so i can waxoyl behind them... Purely for protection. Or is it not worth it?
From my experience, the most common place for bubbling is around the boot lock. I presume if left untreated this would eventually develop into a more severe rust spot?
I'm also on the lookout for a new OEM front o/s wing. Mine has at some time stone chipped, water has got beneath the paint and there are signs of bubbling!
The sills are prone to rusting. See some photos on this post I did a couple of years ago:
http://www.zroadster.net/forum/viewtopi ... inter+jobs
- Badman gee
Re: Do our zeds rust?
this obsession is not healthyZ3cade wrote:As ive never really come across a thread on here bout rust i was wondering is there any places on the zed that can be prone to rust?
I know.. Its getting that bad i want to take all the wheels off and clean under the arch liners..Badman gee wrote:this obsession is not healthyZ3cade wrote:As ive never really come across a thread on here bout rust i was wondering is there any places on the zed that can be prone to rust?
- Badman gee
Just leave it to rust. You could have the first ever "rat" look Z3 in the country
Been there done that, I've had plenty of rat look cars in the past (not by choice I hasten to add). My first motor was more rust than it was car
- hornel Z3M
m
I had my wheels off twice to clean all the suspension and springs with wd 40. the place you will see a problem is where the stones hit the lip next to the wheel arch. i am going to fill the small gap between them with black silicone to stop the water, (thats from washing the car by the way not, rain) getting between them.
Underneath (axle) has quite a lot of rust, but the metal is so thick it doesn't matter for a while.
Driver's door below the quarter light needs doing. Some spots appearing on the sills. Not much else.
For a 13 yr old car it's in good shape .
[edit: I've dug deeper - see my next post ]
If you do let us all know how you got on. I think a previous owner had mine done but I would consider having it done again cost dependantmotco wrote:I'd like to know about this too as I am probably going to get mine Waxoyled.
Well actually it might be Dinitrol. I was having an oil service at Phil Crouch's place in Amersham (CPC Performance) and he mentioned that he could do it so I intend to make a date with him very soon. I don't know exactly what he uses.TitanTim wrote:I can recommend Dinitrol for the box sections and underside as it wont dry out like waxoyl.
I have got the same problem Does anyone know how easy it is to remove the boot lock and if so the procedure?yalden wrote:From my experience, the most common place for bubbling is around the boot lock. I presume if left untreated this would eventually develop into a more severe rust spot?
Many thanks
I've taken off the sills and both rear wings. There is rust on the inside of them all. The galvanising doesn't help now. In fact, it makes things worse. It was great at stopping the car rusting for 10 years, but now there is corrosion everywhere and you can't get to it as it is under the coating. The panels need to be completely stripped and painted from scratch - this isn't going to happen. I'll attack the worst of it and I'll have to live with what's left .
There is no way our cars will last as long as Robert T's frog .
The difference between your frog and our cars is that yours could have been treated by the 1st owner to last. Ours couldn't. Galvanising is great if its done properly with very high quality steel underneath. Ours were built to last 6 years with no external signs of rust. They passed that test with flying colours, but now the steel is starting to break down under the zinc coating (I reckon that it's just cosmetic problems for the next 20 years - so no immediate panic).
- Badman gee
.pingu wrote:I've taken off the sills and both rear wings. There is rust on the inside of them all. The galvanising doesn't help now. In fact, it makes things worse. It was great at stopping the car rusting for 10 years, but now there is corrosion everywhere and you can't get to it as it is under the coating. The panels need to be completely stripped and painted from scratch - this isn't going to happen. I'll attack the worst of it and I'll have to live with what's left .
They will if you keep the car off the road during winter. A salt bath is the quickest way for your car to deteriorate.
The painter I use has suggested bead-blasting the sills back to bare metal . I've started doing the other bits and will probably get them blasted. It's all down to price.
It won't be a new one, though - eek
Unfortunately, some inconsiderate barsteward has been driving mine .TitanTim wrote:They will if you keep the car off the road during winter. A salt bath is the quickest way for your car to deteriorate.
Just done my sills, not an easy job but very satisfiying once done. Replaced some of the wheel arch bolts because they were rusted away and needed some new door seal trim clips as I broke half of mine getting the trim off. I may post pictures to follow.
