Cold start problem solved
Cold start problem solved after TWO cold winters ... I started the expensive way around ... Anyway I changed battery,Ht leads, starter motor ,alternator,plugs ..... Took it to get diagnostic done on it and nothing came up .I came on here and I read it could be the camshaft sensor anyway so I bought that but didn't change it .Then a friend of mine said it could be the air intake sensor and guess what it bloody well was ....to cut a long story short start the cheapest way .
Re: Cold start problem solved
result......... eventually....
thanks for the tip
thanks for the tip
Weird!!
After changing both cam sensors my turned out to be the MAF. Fianlly diagnosed by just unplugging it and saw that i ran better.
