I noticed when I changed my brakelight switch there was also a switch for the clutch pedal, what is this switch for ?
Heath on Tapatalk
Clutch switch
Re: Clutch switch
On my 5 series it to deactivate the cruise control if that helps
Si-forks on tapatalk
E30 318 1988 Gone
E36 320 1992 Gone
E36 328 1995 write off
E39 525d M Sport 2003 Current
E37 Z3 M44B1.9 1997 Current
E36 320 1992 Gone
Clutch switch
I did think they were normally there for cruise control but I dont have cruise control on my zed
Heath on Tapatalk
Heath on Tapatalk
Clutch switch
Often the wiring looms and ancillaries for accessories are fitted at the factory as its cheaper for BMW in the long run. Makes the cruise retrofit relatively easy
Re: Clutch switch
US market manuals had a clutch switch fitted to stop drivers starting the car in gear.The clutch pedal had to be depressed before the starter would operate.
Also there is this mod which may only apply to US market cars.
http://www.zroadster.net/forum/viewtopi ... =5&t=22333
Mod Edit: link fixed to remove IP address - Frank, please use zroadster.net to login to the site.
Re: Clutch switch
UK cars do not have the clutch/starter interlock switch.
On our cars the clutch switch is in the ECU system, and tells the ignition timing circuit that you are changing gear, so allowing a more rapid fall in rpm.
Mine gave trouble while still in BMW warranty, the rpm rising by up to 1500 rpm during a gear change.
Re: Clutch switch
Didn't realise it affected the revs when changing, not something I've noticed on my car. I can't detect what it does but obviously it's definitely there to cancel the cruise.
Re: Clutch switch
Learn something new every day .Mike Fishwick wrote:On our cars the clutch switch is in the ECU system, and tells the ignition timing circuit that you are changing gear, so allowing a more rapid fall in rpm.
Re: Clutch switch
A popular modification in America is to hot wire the clutch switch to permit faster throttle response all the time, which I keep planning to try out, as the Z3 always feels like it has too much flywheel effect. Maybe I'll get round to it this summer.
I think the cruise control cutout is a seperate switch.
Clutch switch
glad you got it sorted
Heath on Tapatalk
Heath on Tapatalk
