Amz wrote:Ive just returned from holiday and then went to start the z after 3 weeks and it wont start. I got the breakdown service to jump it and it started up asap but when i got home after a 15 minute drive and i tried to start it again but it failed.
It seems the battery has lost all charge and is failing to hold charge.
I guess it times for a new battery? or any other suggestions?
Also can anyone recommend any batteries for the z3 between £30 and £70?
Amz
It does sound like you need a new battery. If you have an voltmeter it's worth jumpstarting the car and checking that the alternator is putting out enough juice to charge it, and it could be a bad earth or a number of things, but I'm 99.9% sure you need a battery. I always just go to a motor factor (Motor Parts Direct, Euro Car Parts etc) and buy whatever cheap battery they list - I've found Halfords to be much more expensive. Euro Car Parts normally have some sort of discount code that you can use online to reserve parts and then pick them up over the counter at the reduced price.
I've also bought motorbike batteries online from mdsbattery.co.uk and I think they do car batteries as well, so worth a look - always had good service from them.
('_')Z3
I bought the Bosch S5 3months ago for £72, was great! Yep WAS!
Came to my car after probably 10 days over the weekend and although there was enough charge for clock etc it didn't have enough guts to turn the starter motor, anyway on closer inspection the battery well was 3cm deep in acid. It stripped all the paint from the well
Ouch!!
