deni2s
Post by deni2s »
Got ac schnitzer mirrors painted :) I will hopefully install them this weekend.
Post by Brian H »
deni2s
2 posts, An AC Schnitzer steering wheel and AC Schnitzer mirrors birth without pics, come on!!!! :)
mnbrennan
Post by mnbrennan »
20mm Spacers, a simota induction kit and a rear wiper blanking grommet
Sent from my HTC One using Tapatalk
Now: '99 Z3M Coupe in imola red
deni2s
Post by deni2s »
Brian H wrote:deni2s
Sorry :). Steering wheel pics here: http://www.drive2.ru/l/4180228/ Pics of mirrors will be after installing :)
robdalej
Post by robdalej »
just bought and fitted a wind deflector, off e bay , seems to improve things a bit , had to remove back storage box to be able to get at fixing holed but all good now
Bowler
Post by Bowler »
This weeks purchase for "Nelson"
Stainless steel kick plates to replace the existing roadster ones looking a bit tired
johnz3
Post by johnz3 »
An LED internal light to go with the footwell light fitted last weekend.
A handbrake shoe fitting kit after one of side became detached and started making a horrible noise inside the drum. At first I thought I'd got a stone stuck between the calliper and the disc, but applying the brakes make no difference to the noise, and there was also a bit of rattling going on. I took it to my friendly ex-BMW guy to fix and he sorted it the same day. Seems that as the back plate corrodes, the hole the spring for the handbrake goes through enlarges and the spring can just pop out - the fix consists of adding a washer behind the backplate. Changing the backplate involves removing the wheel bearings, so the washer is a nice cheap fix!
Spotted a Bright Red Z3 1.9 in the workshop which was a bit poorly - new cylinder head gasket going on - quite unusual for an M44.
ARoosterinaRoadster
Post by ARoosterinaRoadster »
Post by ARoosterinaRoadster » 24 Jul 2014, 11:29
Hi to you all again. Well I have just ordered an indirect item for my Z3. It is a dedicated bespoke 7x3 Pent Roof Shed with the sole intention of storing my Hardtop complete with trolley and cover albeit is longer and slightly wider than needed it will also allow the storage of my spare set of original style wheels and tyres (Thank you again Kevin).
I now have a secure storage for the items during their late Spring,Summer and early Autumn Sabbatical from the car.
This post somehow ended-up in the New Project - 1998 M Roadster. I have done Copy & Paste into here after getting a notification of a new post.
Mod Edit: I will go and delete the other post now. R.
deni2s
Post by deni2s »
Simota CF air intake kit and won US spec M3 Schrick cams on ebay, just need to find the way to deliver them to Europe.
Thesurveyor
Post by Thesurveyor »
I had my local independent specialist of choice carry out a few bits and pieces on my "to do" list but the one that has transformed the car is a new throttle cable. My old one had a kink in it (just before the throttle linkage) and had stretched so that when the accelerator pedal was flat to the floor there was still some movement before the throttle bodies were fully open.
The difference is amazing! I think that the kink had to straighten before the throttles opened and this had dulled the response a bit. I imagine that the change is similar to that experienced in high end cars with a sport setting that sharpens throttle response.
Thesurveyor
The emergence of an Estoril blue hard top on Ebay prompted me to search for a fitting kit. Found the brackets on a wrecked 2.8 in a breakers near Ashford complete with only one screen bolt but with the crucial plastic covers for the mounting brackets intact. Then ordered one bolt from main dealer and T40 torx tool from a guy on here.
Fitted brackets on car, won hard top in auction (£455 since you ask) and then drove to Oxford yesterday to fit it and drive home.
Top was in better order than described by vendor so I am a happy bunny. A sticker says it was made in July 1998 and given that my car was made in August of that year it is perfect. It fIts a treat, was quiet on the motorway and didn't leak after being sprayed with the hose. The headlining was covered in dead spiders and bits of web which certainly bears out the vendor's ( a Mini dealer) story that it had been in a storage unit for about four years.
littlefeller
Post by littlefeller »
a dash cam, for £13 :shock: everyone should buy one of these, could save you a furtune. it doesnt have to be exelent video, just enough to show whats going on, or rather what happend :lol: i will wire mine into the heated rear screen switch/loom as i no longer need it but its still all there.
ARoosterinaRoadster
littlefeller wrote:a dash cam, for £13 :shock: everyone should buy one of these, could save you a furtune. it doesnt have to be exelent video, just enough to show whats going on, or rather what happend :lol: i will wire mine into the heated rear screen switch/loom as i no longer need it but its still all there.
Hi littlefeller. I cannot locate my heated rear screen loom without pulling the car to bits,where would be a good place to start looking and can they be felt through the carpet with pressure applied? What are the two semi circular scorelines in the carpet behind the seats and to the central region of that area?
Chiefy
Post by Chiefy »
A new plastic knob that holds the storage bin in place in the boot and a new damper strut for the soft top mechanism.
littlefeller
ummm duno, but mine has a heater rear screen switch, this is located, umm not so easy to explain, i will try - its at the rear of the handbrake, on the trim that goes up at the back, i would imagine any z without it fitted would still have a blanking plate here. i can go through the wiring diagrams and figure out where yours would be if you like :)
ARoosterinaRoadster
Hi littlefeller. I bought my hardtop off of Kevin ( a forum member) after going over to Ipswich and having him fit it for me but gave over looking for the connection because it was getting late and looked like it was about to throw it down and I had a 240 miles + return journey home.
What I am not entirely sure about is just how much pulling to bits is needed to actually locate the connection.
littlefeller
i will have a butchers, but will start another thread as i dont want to clog this one up, i will name it dash cam
ARoosterinaRoadster
littlefeller wrote:i will have a butchers, but will start another thread as i dont want to clog this one up, i will name it dash cam
Hi littlefella. OK but why dash cam? Is that because the power feed can be taken from the same point?
the Nefyn cat
Post by the Nefyn cat »
Actually bought them last week, but only got them on this evening, a set of Spax VSX dampers and springs from Larkspeed. Only had a short drive with them fitted so far but seems good, one unexpected bonus is that the metallic-sounding ting-ting noise from somewhere in the back end seems to have gone. The ones that came off looked original to me, twelve and a half years may have been too much for them, the old rear dampers had about two inches of travel before anything happened. Don't know if it's been mentioned before, but if anyone else feels like doing it themselves, it's all quite easy, make sure you've got a very sturdy 18mm socket and a long breaker-bar, the front bolts on mine were fighting all the way out. Must have used some serious Loctite-type stuff at the factory.
littlefeller
the dash cam comes with a cigarete lighter socket plug, but i dont want the wires dangling down, so i will use another 12v feed, the heated rear screen switch is redundant so i will use that :)
Post by Southernboy »
...... VDO Oil temp sensor.... currently with Fedex, but delivery will be tomorrow.... so oil and oil filter change this weekend and fit the "new drain plug / temp sensor"...
US 24.00 M12 X 1.5 thread as per OEM drain plug...
lordhelpus
Post by lordhelpus »
Centre armrest courtesy of 'southernboy'......left elbow now has a place to go. :D
Captain
Post by Captain »
New set of Toyo Proxes T1 Sport Tyres, just need to scrub them in. :D
.... How's the Z3 going Hilton?
Captain
Post by Captain »
Southernboy wrote:.... How's the Z3 going Hilton?
Going really well thanks Barry
ZZZ
Post by ZZZ »
Payed 57 euro (in Netherlands) for Seat Belt Guides....
In 4 afternoons I need to replace seat bushes, fix seat heaters ( serious concerns about that) , condition the leather and sew some broken section, replace seat belt guides, install roll hoops... :dunce:
hahaha sounds funny... :head: :bawl:
so far lots of print out from knowledge base.... :rtm:
there's a set of seat belt guides for sale on the forum from Davidz3...£25 !! .......or had you already ordered the new ones from Holland?
ZZZ
Post by ZZZ »
I am in Holland :) so I ordered already :oops:
...... ah...OK then... good luck with the rest of your maintenance tasks... :wink:
ZZZ
Post by ZZZ »
Thanks! with some luck it should be ok.... just that heated seat and cheek burn storiess :D
Neutro999
Post by Neutro999 »
new fuel filler cap, 6 months tax and autoglym fabric hood care kit (only the best for my boy) :)
'01 Z3 3.0i with black leathers - a.k.a 'The Rebel'
Topperz
Post by Topperz »
Set of ACS front splitters/flippers that were listed on the bay
Still in transit and fingers crossed they fit my z ok
Will do a test fit when they get here then decide wether to get them painted of carbon fibre wrapped
I'm thinking carbon Matt black might look good on cosmos black.....any thoughts would be good
Will post some pics when fitted :rtm:
The only bad thing about owning a Z3 is bedtime .......boing!! time for bed said zebedee
Z3 cosmos black individual 2.0
X1 /MSport XDrive 2.0d mineral white
ARoosterinaRoadster
g8jka wrote:2 new tyres for the front wheels and 6 months tax
Hi g8jka. I am running those all around on my Z3 2.0ltr Auto. I got mine from Pemberton Tyres,Pemberton,Wigan. I have been buying from them since very soon after they opened in the current premises - having moved from a little further down the road and previously nearer to Wigan.
Where are you in Liverpool?
ARoosterinaRoadster
Hi to you all. I am trying to upload an image but I am getting this ;-- Sorry, the board attachment quota has been reached.
What is it all about and how do I correct the issue or does it mean that I delete all of my saved images :shake: and throw away my camera? :head:
TR4man
  Z4 coupe 3.0si
Post by TR4man »
You are better saving your photos in something like Photobucket, then just copying the IMG code and pasting it into your post.
ARoosterinaRoadster
TR4man wrote:You are better saving your photos in something like Photobucket, then just copying the IMG code and pasting it into your post.
Hi TR4man. I was of the understanding that when an image is uploaded from my PC onto this or any other forum that it is published and then forgotten about and does not actually constitute or count towards an "Album" that can then become full.
How do I correct the matter ?
Bowler
Post by Bowler »
present from the Classic car show, a full cover to keep him snug during the winter months
Koolflyer
Post by Koolflyer »
Me too, which one did you get??
Bowler
Post by Bowler »
Went for one i think was called simply car covers it
is triple layered with a cotton lining with the promise of being fully waterproof but breathable cost £40
Post by g8jka »
Hi Rooster, I think you have me mistaken with another member, I am not in Liverpool, actually in Telford :)
By the way, I bought a new battery for my zed this week.
ARoosterinaRoadster
Hi g8jka. Absolute apologies for my unforgivable error - yes I can see that now. I had actually picked up on an earlier post that seemingly had your forum ID attached to it but I cannot recall where the link/connection with Liverpool came from.
It is not an excess of wines or booze,it must be linked to an ultra rapid and transitory dementia - onset.
mnbrennan
Post by mnbrennan »
£40? Where do I get one?!
Post by peter2b »
Just fitted a new(second hand) slam panel and 2 head lights also second hand just need a bonnet then can her back on the road
Peter2b
Toony
Post by Toony »
MOT - no advisories :D
Oil, Oil Filter, Air Filter and Spark Plug Change :) .
Service Light Reset :)
The Red Zed has been spoilt rotten this week - still she's worth it. :wink:
tower
Post by tower »
Gearbox and diff oil....oil change next week
TR4man
  Z4 coupe 3.0si
Post by TR4man »
Professional refurbishment of the driver's seat for £65.00
Money well spent.
Post by TitanTim »
New battery a couple of weeks ago.
A couple of litres of Dinitrol underbody wax and now all done for winter :)
AlsZ
Post by AlsZ »
The Wiesseman Z3 hardtop that was on sale here and on ebay.
Had a few scuff marks on it so James knocked a few quid off (so got it for £750), very pleased with that.
My Z is a red 2.8, the colour contrast looks great, I thought about having it sprayed red but I reckon it looks pretty good in black (I think it is cosmos but not certain), hope to put a pic on here tomorrow.
Was a bit of a trek from Cheddar to Morecambe on Saturday but much more enjoyable coming back and surprised how quiet the cabin was.
Al
Post by peter2b »
New radiator fan, £19.95 + n/s head light £45 ,getting there only 6 months till me mans trip
Peter2b
