yalden
Post by yalden »
I've also seen people use washers and stubby bolts to refix the panels.
Post by peter2b »
new boot struts so swmbo can open it
Post by Gazza »
A new heater blower resistor, blower not working on 2 & 3.
Exhaust box mount.
A new coat of paint for the CSL.
Post by bertiejaffa »
g8jka wrote:Best way to attach them back on is to clamp it back onto the door card and fill the holes where the plugs were with glue from a hot glue gun. This was what I did when I wrapped mine in carbon fibre vinyl.
x2 for the hot glue gun approach - works great recreating the studs with the hot glue. Southernboy went a step further and drilled and taped what was left of the rubber studs and then used micro screws and washers to recreate the studs - like Yalden mentions above - I think Southernboy has too much time on his hands :wink: :wink: :lol: :lol:
Post by Southernboy »
Lee, screws are removable...so I can always go back there without having to deal with glue / melted plastic studs again.... But if you're sure you're never going to do anything there again, then glue gun is a good solution. :wink:
yalden
Post by yalden »
Bought a while ago, but received today...
Southernboy wrote:Lee, screws are removable...so I can always go back there without having to deal with glue / melted plastic studs again.... But if you're sure you're never going to do anything there again, then glue gun is a good solution. :wink:
I knew there would be an engineering solution :wink: My option is a bit more ham-fisted with a dremmel ha ha
yalden wrote:Bought a while ago, but received today...
Gulp !!
Post by gookah »
peter2b wrote:new boot struts so swmbo can open it
From the inside?
ALPHA 3.0i Z3
Post by ALPHA 3.0i Z3 »
Anyone know if chrome mirror caps are available for a z3? If so could you direct me where. Or do you have any ideas? Could I adapt something else to fit? Must be removable. Oh and I'm buying door handle chrome covers.
Who says size doesn't matter? After a straight 6 3.0 litre....Its hard to go back .
Rafolian
Post by Rafolian »
Just ordered pair of boot lid struts, £21-50 inc postage to Spain!
Post by peter2b »
just fitted new struts to her boot, nearly knock me out
peter2b wrote:just fitted new struts to her boot, nearly knock me out
ha ha - warned you... Those new struts make it fly open!!
Not for the Zed, but you have always got to give credit to Jack...
Boosh
Post by Boosh »
A tonneau cover for RedZed. Thanks GD, pleasure meeting you.
Boosh.
kjb1
Post by kjb1 »
New track rod ends, including inner's.
Replaced near rear side brake pipe
New pads all round
Cured my leak
New BMW wheel centre badges
It's MOT. Passed, but needs a new handbrake cable. Not sure what it is with my cars and their handbrakes at the moment - the button was stuck in on the one on the Sprite meaning that the ratchet didn't work - think I have fixed it now, just need some warmer weather to get it put back on the car.
Robert T wrote:It's MOT. Passed, but needs a new handbrake cable. Not sure what it is with my cars and their handbrakes at the moment - the button was stuck in on the one on the Sprite meaning that the ratchet didn't work - think I have fixed it now, just need some warmer weather to get it put back on the car.
handbrake turning them around the bends again Robert ?? :lol:
kruisn
Post by kruisn »
Have you seen the quick alteration you can make to the sprite handbrake that makes it a "fly off" handbrake Rob? That would give the MOT pricks a jolt. Heh heh. :devil:
Don't drink and drive home -
Take the Zd and fly home -
kruisn wrote:Have you seen the quick alteration you can make to the sprite handbrake that makes it a "fly off" handbrake Rob? That would give the MOT pricks a jolt. Heh heh. :devil:
I was actually looking at the photos for this mod to figure out how to get mine apart. Turned out that someone had missed fitting a washer and that the button went in too far, allowing the pin that holds the button on to catch on a flange inside the handbrake lever. Fly-off sounds like it might be a bit scary for anyone else to drive, so I'll hold off doing that unless I take it sprinting. :lol:
Post by peter2b »
just went to Shrewsbury BMW garage ordered new bulb for the heater knob and a light switch £59 not in stock, they had only sold 1 bulb since they opened
kjb1
Post by kjb1 »
what bulb is it Peter?
Sent from my iPhone
kjb1
Post by kjb1 »
peter2b wrote:just went to Shrewsbury BMW garage ordered new bulb for the heater knob and a light switch £59 not in stock, they had only sold 1 bulb since they opened
and how much? one of mine is out
Sent from my iPhone
I got mine from BMW in Manchester - the bulb wasnt cheap but it wasnt £59 - around £8 if I remember rightly
Post by g8jka »
I'm pretty sure that was me who had the said bulb from there :lol:
Post by peter2b »
don't blow that often then, do you know what they are like cost wise for servicing zed's?
peter2b wrote:don't blow that often then, do you know what they are like cost wise for servicing zed's?
I would suspect "Ouch"... There are a few BMW specialists in Manchester, but to be honest I also think they are on the Ouch side as well. I have a good indi in Manchester that does mine - Autocare Assist on Whitworth Street - Ask for Steve and mention my name (and wait for the screams :lol: )
kjb1
Post by kjb1 »
Fitted a set of front mud flaps. treated rust ( only bit of rust on whole car ) that they have hidden on sills, now looks totally mint :) :) :) :) :) :)
kjb1
Post by kjb1 »
Sent from my iPhone
TWO
Post by TWO »
Front mud flaps look good......are they OEM?
kjb1
Post by kjb1 »
You cannot purchase new mudflaps oem from dealer as they have been discontinued. These surprisingly are Halfords universal fit £9.99 ones!!
Sent from my iPhone
TWO
Post by TWO »
kjb1 wrote:You cannot purchase new mudflaps oem from dealer as they have been discontinued. These surprisingly are Halfords universal fit £9.99 ones!!
Sent from my iPhone
That's why I asked :) ....OEM are as rare as rocking horse s*** :)
kjb1
Post by kjb1 »
Yes I did try also, but for £10 I am very happy with these, cheap fix.
Sent from my iPhone
TWO
Post by TWO »
kjb1 wrote:Yes I did try also, but for £10 I am very happy with these, cheap fix.
Sent from my iPhone
Look like a good fit :)
Gookah has fitted them too - I think he trimmed them down slightly so as not to catch on speed humps etc - I think I will be doing the same before too long
What kind of speed humps? My OEM ones occasionally catch on a kerb, but never on speed humps.
ARoosterinaRoadster
Post by ARoosterinaRoadster »
Hi to you all. Since fitting staggered wheels to my 2.0 ltr Auto Z3 and very recently I have also fitted 20mm spacers to the rears the car now not only looks right but looks like the wheels were meant for it.
I will be investigating my local Halfords in the morning with the probability of front and rear protection - possibly after a bit of trimming has taken place.
kjb1
Post by kjb1 »
and yes trimming is required, not to mate them to the lines of the body work, but simply, to the contours of the universal fit for the overall size of the mud flaps, you simply cut along where the smaller contour exists, job done!
well worth a £10'er
Post by gookah »
Robert T wrote:What kind of speed humps? My OEM ones occasionally catch on a kerb, but never on speed humps.
The ones on our estate and the little ones that sit in the middle of the road. For the later ones I always just take a different route, for the ones on my estate - they are bordering on joining the 3 peaks challenge !
Bonzo
Post by Bonzo »
Not this week, but fairly recently. New springs and shocks all round (OEM), new front strut top mounts and rear shock top mounts, new heavy duty drop links front and rear, new ARB mounting bushes front and rear, new rear calipers, new rear brake discs/drums, new h/brake shoes and internals, new ATE TYP 200 road/race brake fluid and new Yellowstuff brake pads. All ready for the Snetterton track day...... But I got a chest/throat infection the day before and felt so rough I couldn't make it! :bawl: :head:
cheers all, :cheers
Bonzo.
Post by peter2b »
I can see :) new heater switch bulb fitted and a new head light in plus one of our cows had a nice calf when I was in my man shed only took her 6 min to have it
Z3Jeremy
Post by Z3Jeremy »
What didnt i buy my zed this week?!? popped into Dorchester BMW for a fuel filter, deep breath, £48 exactly if you please!! GSF it is then £12...J
Rafolian
Post by Rafolian »
The usual 2 to 4 weekly auto carwash and dry, 3-50 euros, and a vacuum 1 euro!
ARoosterinaRoadster
I recently bought and had fitted some 20mm hub concentric spaces for the rear of my 2000 (W) on personalised plate Z3 2.0ltr Auto.
[img][IMG]http://i927.photobucket.com/albums/ad11 ... kmen4q.jpg[/img] [/img]
Post by peter2b »
Sent from my iPhone
bulb was £9.98 :? light switch £39.47
ALPHA 3.0i Z3
A baby engines 2006 Z4....its only the 2.0i but car is mint and the misses is happy...later will be a 3.0i though a matching pair of 3.0is....But a very nice clean car she is.
A
Boosh
Post by Boosh »
Handbrake cables, springs, and shoes. That'll hopefully sort out my rear driver's side wheel heating up...
Boosh.
kjb1
Post by kjb1 »
put a new steering wheel on today, old one looks so old fashioned incomparison
Sent from my iPhone
kjb1
Post by kjb1 »
new gear gaitor and hand bake gaitor, new window switches ( mine were damaged ) and a new set of boot struts!
Sent from my iPhone
