Front disk, pads and caliper kit
John1950
Post by John1950 »
I spotted this on E-Bay today:
http://www.ebay.co.uk/itm/BMW-316-318-3 ... 3ccb295ed0
As I have a 2.8 with OEM standard brake set-up, can anyone advise me if these are worth changing too?
John Walker
Baarn, Holland
Image Image
John1950
Re: Front disk, pads and caliper kit
Post by John1950 »
Zedonist wrote:Hi John, they are the same as your standard set up, which should be 286mm x 22mm vented discs, not bad value if you want to overhaul the system mind
Well, the front disks are very near needing replacement, the callipers look old and rusty and the pads are getting low so I thought 'do it all in one go'. I was also thinking of using Hammerite paint on the callipers to prevent rust but I'm not sure if it's heat resistant enough.
John Walker
Baarn, Holland
Image Image
