steering wheel
wyn02
steering wheel
Post by wyn02 » Tue 01 Jan, 2013 11:51
Hi guy's and happy new year. Couple of questions, while taking off the radiator to change the thermostat which was a piece of cake to do thanks to all on this site, I noticed that there was a second air intake pipe beneath the normal intake but this one went into the back of the alternator,
does anyone know why. The second is I was given a new steering wheel off my wife for Xmas. I've taken the airbag off but can't free the wheel nut, its really stuck. Is it a left hand thread? Thanks.
Mod Edit: Triple post cleaned up and replies merged into one thread. R.
Captain
Re: steering wheel
Post by Captain » Tue 01 Jan, 2013 12:19
The steering nut is a normal thread.
Sent from my HTC Desire
si-forks
Re: steering wheel
Post by si-forks » Tue 01 Jan, 2013 14:12
My 1997 Z the steering wheel was just a normal thread 16 mm i think one good crack to the left and it was off
Si-forks on tapatalk
E30 318 1988 Gone
E36 320 1992 Gone
E36 328 1995 write off
E39 525d M Sport 2003 Current
E37 Z3 M44B1.9 1997 Current
Mike Fishwick
Re: steering wheel
Post by Mike Fishwick » Tue 01 Jan, 2013 16:20
A cold air intake to the alternator? What do you think it's for . . . cooling of course! Even a Meerkat could figure that one out!
Re: steering wheel
Post by TitanTim » Tue 01 Jan, 2013 16:22
Mike Fishwick wrote:A cold air intake to the alternator? What do you think it's for . . . cooling of course! Even a Meerkat could figure that one out!
:lol: :lol:
wyn02
Re: steering wheel
Post by wyn02 » Tue 01 Jan, 2013 17:44
Sarcastic arse, I only asked!!
Re: steering wheel
Post by TitanTim » Tue 01 Jan, 2013 17:57
wyn02 wrote:Sarcastic arse, I only asked!!
Any pics if the steering wheel installed Wyn?
Mike Fishwick
Re: steering wheel
Post by Mike Fishwick » Wed 02 Jan, 2013 13:04
Oh dear - I am starting the New Year after annoying yet another over-sensitive soul!
I was not being sarcastic, but was amused by your inability to perform the simple calulation of: Cold air inlet +Alternator = Cooling for alternator. Did you really need to ask?
At least I bothered to answer your question, which is more than anyone else did!
Why are people so touchy these days . . .
Bonzo
Re: steering wheel
Post by Bonzo » Wed 02 Jan, 2013 13:41
Mike,ever thought about a career in The Diplomatic Service, or Acas? :twisted:
geminimustang
Re: steering wheel
Post by geminimustang » Wed 02 Jan, 2013 14:20
You can only reply to the question if you know the answer.At the age of 52,I've learn't something I didn't know,namely,alternators benefit from cold air being directed on to them.I have a further question but I'm too frightened to ask!!!!
Bonzo
Re: steering wheel
Post by Bonzo » Wed 02 Jan, 2013 14:27
Chicken! :lol:
geminimustang
Re: steering wheel
Post by geminimustang » Wed 02 Jan, 2013 15:01
Rich,you're just after a ride in my zed,hope little Zedonist is keeping well?
Re: steering wheel
Post by BladeRunner919 » Wed 02 Jan, 2013 16:44
geminimustang wrote:I have a further question but I'm too frightened to ask!!!!
Go on, I dare you!!
Re: steering wheel
Post by TitanTim » Wed 02 Jan, 2013 16:54
I will answer any question, but it may not be the correct answer.
I have to ask, why on earth would you want a cold feed to an alternator as I'm unaware they get hot :? Or is Mike pulling your chain :lol:
Mike Fishwick
Alternaor Cooling
Post by Mike Fishwick » Wed 02 Jan, 2013 17:44
Well - think about it - on full load our alternator can produce an output current of 90 amps, which at 14 volts works out at 1260 watts. A typical three-phase alternator operates at an efficiency of around 80%, so 20% of the output power is wasted as heat - or 250 watts.
Think of this as four 60 watt headlamp bulbs, which if contained within an enclosure the size of an alternator would make it quite hot, even without the heat it absorbs from the radiator etc.
The external cooling fan fitted to most alternators would simply draw in hot air from the radiator, in addition to its internal 250 watt heating effect on full load - when the alternator is charging the battery and feeding headlamps etc. In hot countries such as California, of course, the situation is even worse.
So - some form of cold air inlet is a good idea, which will feed the internal cooling fan and pass through the alternator to extract heat from the rotor and stator, so providing good cooling in all conditions.
Large alternators on ships (typically 500 or 650 kilowatts) frequently have a sealed primary cooling air system, with an air/sea water cooler to extract the heat and throw it overboard, while really massive alternators in power stations (typically of 1200 megawatts) use a closed primary cooling system of pressurised hydrogen, which usually passes the heat into the cooling water system.
wifevanda
Re: steering wheel
Post by wifevanda » Wed 02 Jan, 2013 17:57
i knew that
geminimustang
Re: steering wheel
Post by geminimustang » Wed 02 Jan, 2013 18:01
My further question is a). Is this cooling still seen on today's cars or only seen on older models.Seems a very antiquated way of cooling,e.g. A bit of pipe.
Re: steering wheel
Post by Del » Wed 02 Jan, 2013 19:31
I agree with geminimustang. Lots of cars don't have such ducting and my 4-cylinder Z3 hasn't got it. It seems to be a feature of the 6-cylinder engines. I assume its down to a combination of a packed engine bay and small front grills.
Brian4
Re: steering wheel
Post by Brian4 » Wed 02 Jan, 2013 20:31
Some of the 5 series and X5's have watercooled alternators.
3.0I Topaz Blue
2000 E36/7 Z3 3.0i
2016 F31 335d
2015 F21 118i
Re: steering wheel
Post by pingu » Wed 02 Jan, 2013 21:58
Brian4 wrote:Some of the 5 series and X5's have watercooled alternators.
Something else to go wrong :shock: . A bit of air pipe can be easily improvised.
wyn02
Re: steering wheel
Post by wyn02 » Wed 02 Jan, 2013 23:19
Thanks for a sensible answer. Til today I too never knew an alternator needed cooling. Thanks every one.
Re: steering wheel
Post by Southernboy » Thu 03 Jan, 2013 05:05
Cool!! :D
Mike Fishwick
Re: steering wheel
Post by Mike Fishwick » Thu 03 Jan, 2013 13:09
There is a cold air intake for the exhaust side of the engine, but that on the inlet side is used to hopefully feed the air filter - if the air can stop, reverse its flow, and turn an acute left-hand bend! A lot of cars are supplied with sufficient cold are around the alternator.
