alarm led
Re: alarm led
It's a switch as well as an led. If you press it in before setting the alarm it disables the motion sensors.
Re: alarm led
Is it the small round alarm light? If so it is as Bladerunner919 describes.
The alarm systems changed from the separate keyfob type to the integrated fob type in and around 1999 IIRC, the change in system also changed the style of indicator light. I had a look at your profile and was not sure that the small round light was fitted to a 2000 model?
Re: alarm led
Yes its just one small led, it doesn't seem to be a push button.
Re: alarm led
It is. It's probably just stuck.wyn02 wrote:Yes its just one small led, it doesn't seem to be a push button.
Re: alarm led
It's probably the same as mine was, the red plastic cover cracked so it's not obvious that the broken cover used to be a push button. It plugs into the alarm module behind the glove box, part 4 on this diagram. It's £11.51 from Cooper BMW and comes as an entire plug/cable/switch - you can't buy the plastic cover separately.
1997 2.8 Z3 | Gallery Thread
Re: alarm led
Thanks all. I'll order one from there.
Re: alarm led
Hi Wyn - did you manage to get this part I have just tried CooperBMW and they say they cannot source it?wyn02 wrote:Thanks all. I'll order one from there.
Re: alarm led
Hi j. I ordered it but later was told that they no longer stock it. So still got a broken dash bulb. Has any one got any ideas of a replacement.
Re: alarm led
The switch is just a momentary switch with illumination, sourcing another one might not be too hard if you do not mind it looking a little different. IIRC there are three wires that connect the switch:
- Common
Trigger
Light
Re: alarm led
Could you use something like this?
Re: alarm led
Almost. That one latches - Brian said it was a momentary switch. The four pins shouldn't be a problem, just tie (well solder) the returns in a common. Depending on the voltage of the LED, it may need an appropriate resistor in series with it.g8jka wrote:Could you use something like this?
Re: alarm led
That looks better, Brian. The LED is sold separately, so you should be able to get one the right voltage - the one they link to is 12v - you'd need to check what voltage the alarm puts out with a multimeter, unless the rating of the original LED is given somewhere.Brian H wrote:RS Components have a switch which I think will do.
Cheers R,
Re: alarm led
I no longer have this type of switch, if someone measures/confirms the voltage I have an account with RS and could put a few together with cable tails on if people are interested?Robert T wrote:That looks better, Brian. The LED is sold separately, so you should be able to get one the right voltage - the one they link to is 12v - you'd need to check what voltage the alarm puts out with a multimeter, unless the rating of the original LED is given somewhere.Brian H wrote:RS Components have a switch which I think will do.
Cheers R,
Re: alarm led
Thanks guys - great input and assistance as always. Will have a go at measuring voltage over the weekend.
Re: alarm led
Have had a look today. As previously mentioned, there are 3 wires dark blue, silver grey and brown. There as a permanent 5v on dark blue. Silver grey pulses between .3 and 1v when system is armed (i.e flashing light).Brian H wrote:
As you said Brian an RS will be slightly different but as our Zeds age and spares become rarer it's something we have to accept.
Colin
Re: alarm led
I also have this problem now. It went walkabouts after coming back from the garrage for a throttle cable replacement and a new soft top. I've looked everywhere in the car and can't find it.
Has anyone sourced a replacement switch?
To be honnest i neved used it. It just looks bad without it.
Any help would be greatly appreciated.
Re: alarm led
[quote="Damon"]..........Has anyone sourced a replacement switch? [quote]
From my experience I think the only way you will get a proper replacement is from someone breaking a Zed - there are a few going at the moment.
On mine the LED was still working (I still had the lense cover) but the switch was not. I had a great deal of assistance from a fellow forum member and although he found a switch to do the job, the current is so low we could not get the light to illuminate when it was installed. I ended up with a compromise in that the original led was still used and the replacement was installed as switch only.
Suggest you keep looking under the seats - it will have pinged off somewhere in the car.
Re: alarm led
Thanks for the quick reply Jonco.
I'll have another look around. Without taking the seats out I don't see how I can look any harder. On the plus side I did find £1.01. There is also the chance (as the roof was being replaced) that the roof was open when the button was bashed. It could be anywhere in their workshop. Sounds like its a trip to the breakers. There is a switch/button on ebay for £25. I don't like the look of it though.
