Wobbly door mirror
Alan W
Wobbly door mirror
Post by Alan W » Sun 07 Jul, 2013 20:13
The driver's door mirror housing on my Z3 has a little bit of left/right play on it causing it to annoyingly 'shake' when on the move (caused by airflow) is this a common fault and more importantly does it have an easy fix?
Thank you
Alan
Re: Wobbly door mirror
Post by BladeRunner919 » Mon 08 Jul, 2013 08:35
I don't know that it's a common problem - normally people have the opposite, that they've seized solid. Is it definitely the whole housing and not just the glass that's vibrating?
Alan W
Post by Alan W » Mon 08 Jul, 2013 09:58
Hi Bladerunner, its deftinately the housing and not the glass, gives the impression that something in the foot / base needs to be tightened up?
Post by Robert T » Mon 08 Jul, 2013 10:10
Hate to say it, but it could be that previous owner had the mirror mount break on them and they a applied a "temporary" fix to it. The alloy bracket inside the mirror is prone to corrosion and after 10-15 years it does not take much to break them. There are two possible fixes that I know of, and it depends what is left that is still solid as to whether the putty solution will work, or whether you are better buying either a replacement plastic insert or a complete mirror. There was some debate on this recently - the plastic insert is not cheap, but it is a permanent fix, whereas a second-hand mirror is likely to suffer the same fate as the original within a few years.
Putty Fix: http://www.zroadster.net/forum/viewtopi ... =5&t=37586
Plastic Insert: http://www.zroadster.net/forum/viewtopi ... =5&t=38362
woodsta888
Post by woodsta888 » Mon 08 Jul, 2013 21:30
Or mine if it's only the steel collet that's rusted. Drill it out and use stainless steel nut and bolt to take up the tension in the re usable spring spring. Permanent and the mirror still folds backwards.
http://www.zroadster.net/forum/viewtopi ... mi#p319059
Best
Steve
