Seat motor fault
Seat motor fault
The passenger seat of my Zed appears to have a fault...
It moves backwards and forwards okay but not up and down.
When I push the switch up or down I can feel and hear a dull thud like the motor trying to start then nothing happens?
I am therefore guessing that the mechanism is seized rather than the motor defective?
Is this common - and more importantantly - easy to rectify?
Thank you
Alan
Thank you
Alan
Re: Seat motor fault
On mine 2.8 it was stuck in one of the extreme positions. I don't remember exactly what I did but I remember it was fairly easy - loosen the seat and get the mechanism loose with a pair of pliers, grease it up, and then it worked perfectly.
I did not loosen any of the electrical wiring to do this just loosened the seat so I could tilt it and get access.
Too loosen the seat, have the seat in upright position, take it as far back as possible, unscrew and remove the front nuts, move the seat extreme forward and loosen the rear bolts. If I remember correctly you need a 13 mm socket for the nuts in front and a 17 mm in the back. The ones in the back can be a bit of a problem to access, and do check for small stones in the grooves around the bolt that otherwise will hinder your socket to get a grip.
If it doesn't come right, contact Stupot on the forum...he is considering breaking a Z3...you could get all the spares from him.
Thanks for the heads up Southernboy, do you know what year / model / body colour / trim colour?
And thanks Kornknarr for the guide to removal
I think all the seats are the same as far as motors go...so it isn't an issue in that respect. Stupot's post is on the current list of topics...so you can PM him and get first dibs on seat motors...
Your seat motor will be fine, sit on the seat and flick the seat button up and down quite a few times, the mechanism has gone to the end of its travel and got stuck but should release with a bit of patience.
Correct, they are even interchangeable but the coloured wires on the motors will be wrong.Southernboy wrote:I think all the seats are the same as far as motors go...so it isn't an issue in that respect. ......
Tried this to no avail so unbolted seat this morning and had a look underneath, the seat was is its fully raised position and the 'screw' was locked tight. Unbolted the pin bolt and with a bit of grunt its all freed off and working fine. Will just make sure that I dont let any passenegers move the seat to fully up or down in case it happens again. What causes this to happen - lack of use?Your seat motor will be fine, sit on the seat and flick the seat button up and down quite a few times, the mechanism has gone to the end of its travel and got stuck but should release with a bit of patience
Lack of use and lubrication will cause the seat mechanism to stick, I have had this a few times on my drivers seat but luckily managed to release it with the switch.
Does anyone have a way of limiting the max seat height (to ensure that it doesn't jam some time later on) ?
just found this item. my drivers seat went back and forth OK but not up or down , sat in seat flipped switch up/down quickly bingo now work fine,great help cheers
If you need any parts i have two seat bases with all the parts sat in my garage.
Lee
Lee
Don't you need to be flogging them to Ash!Joycey wrote:If you need any parts i have two seat bases with all the parts sat in my garage.
Lee
I'm on here too Dave
Ash
Ash
Lol I know!!ashbandicoot wrote:I'm on here too Dave
Ash
