Got my plates on my way to put on the M Roadster, are the rear ones glued/double-sided/what?? How do you fix them? Whats the best method.
I know it sounds straightforward but i am novice at this type of stuff and want to get it right rather than my usual "it'll do" approach.
Thanks in advance.
tags
Adhesive for number plates
I got my plate adhesive strips from the dealers, however, if you have an illegally spaced plate it's pain when Rob Bruce pulls you over and tells you to put on your legal versions
Tony's solution to this is the most obvious especially if you've got screw caps that match the plate (ie yellow or white)
On my last Z3 i got stopped once regarding my plate spacing. This was after having them on for 2 days. I promised the policeman that i would change them and he said that i would look stupid if next time he sees me in warrington i still hadn't changed them. Well, i didn't and never ever got stopped again. I also never went to warrington much anymore, the bird up there turned out to be a bit of a stalker
