While driving away 50 yards from home, the doors on my 1997 1.9 Z3 suddenly locked, the fuel guage showed zero, the temperature guage showed maximum. Turned back to the house, checked fuses, to find fuse 46 blown. Replaced fuse and car has been fine since.
What could this be?
Many thanks in advance for any suggestions.
Kind regards
serow
what is going on ?
Re: what is going on ?
Did you have your boot open prior to driving away? Fuse 46 covers quite a few items but one is the brake lights. The loom in the boot is prone to work hardening over time and when it breaks (wires snap and short out) it can course some funny symptoms. Central locking wires also run through this loom. Maybe a place to start?
Thanks brian chucked roof cover in boot just before setting off will check loom when i get back home next week and will let you know result
Hi brian returned from hols checked and found the loom of doom put in one new wire and repaired (solder) two all is now well
Thanks again Serow
Thanks again Serow
Glad you got it sorted
I like that "the loom of doom" , it is quite alarming that such a small loom can cause so much trouble with so many symptoms.serow wrote:.......the loom of doom.........
Me too! Sums it up perfectly. Reminds me that I want to do this http://www.zroadster.net/forum/viewtopi ... 18&t=34807 as a pre-emptive repair.Brian H wrote: I like that "the loom of doom"
