Hey people I have a 2000 facelift Z3 and have notices theres a lot of water situated under the carpet (under the seats) and has been appearing in the battery tray also. My boyfriend has sorted the 3rd light out (by siliconing it) and the boot carpet seems to be dry... So we are really stuck for the minute. It has also just had a new roof so I would assume its not leaking from there.
Any help would be great.
Leaking water in Z3
Re: Leaking water in Z3
Hi T4L, have you checked the drain chanels from the top of the windscreen corners? these can get blocked and force water elsewhere inside. Check in the 'How to' section on here, there is a thread with photos to help you check them. I used a large tyewrap to clear mine, strong enough to follow the chanel but flexible not to do any damage.
Sorry to be a bore, but can you link to that article ? (I canne find it)
Couple of possibilities here:
http://www.zroadster.net/forum/viewtopi ... =3&t=35770
http://www.zroadster.net/forum/viewtopi ... =5&t=36095
Many thanks for your replies guys. To be honest it has really put me off the car because of this. I have recently had a new roof done by Jack Smith in Swansea, South Wales (highly recommended) but he siliconed the rubber area at the top of the windscreen sealing this hole up. I assume he knows what he's doing lol.
We had a heavy down pour today and saw it trickling from the middle and the front of the passenger window so I assume it is the area that everyone is talking about.
What else is seriously baffling me and my boyfriend is that there is water appearing in the battery tray (frequently) and there is no wet carpets in the boot. The 3rd brake light has been siliconed so it cant be that, so we are really stumped... All help as I said us much appreciate.
Tal
Tal
Leaks into the boot tend to either get in via a perished aerial grommet or the third brake light seal.
Leaks via the roof (as mentioned above) are very commonly caused by the rubber bungs at the top of the windscreen pillar posts. Sometimes by the glass on the side windows not meeting the rubber roof seals correctly, or the bottom corners of the rear window becoming unstuck and becoming "untucked" from under the rubber surround strip - I wouldn't think this latter issue would be the problem on a new roof.
Del wrote:Leaks into the boot tend to either get in via a perished aerial grommet or the third brake light seal.
Many thanks del. As for the aerial grommet and the 3rd brake light they have been sorted but still getting a puddle in the battery tray... bit of a mystery if you ask me...
Check for any signs of water in the offside rear light. My mates did this and it was due to the seal behind the light.
1999 2.8 Arctic Silver Z3
2007 325d Msport - remapped
+1 for this, sometimes the gasket is either perished or just mis-aligned.stupot50 wrote:Check for any signs of water in the offside rear light. My mates did this and it was due to the seal behind the light.
