Expensive Z3 water pump !!!
Woody1000
Post by Woody1000 » Fri 10 Jan, 2014 20:37
Well I think the most expensive water pump arrived this morning from the US, well if didn't actually arrive I had to pick it up from Parcelforce !
So laid out £146 for the pump including postage to the UK then Parcel force wouldn't delivery it until I paid a further £41 for handling and VAT import charge !!
£187 !!! Or £37 from the bay !!!
And it only pumps water around !!
Mint
Re: Expensive Z3 water pump !!!
Post by Mint » Fri 10 Jan, 2014 20:47
Woody1000 wrote:Well I think the most expensive water pump arrived this morning from the US, well if didn't actually arrive I had to pick it up from Parcelforce !
Phew - you must have deep pockets, looks a good piece of kit. What price peace of mind though?
Davejue1
Post by Davejue1 » Fri 10 Jan, 2014 21:23
Big ouch!!!!!
Post by Brian H » Fri 10 Jan, 2014 21:55
I had a similar import charge on an electrical item last year, it seems that they select random parts to check. You will have piece of mind though once the pump is fitted.
Post by Del » Fri 10 Jan, 2014 22:28
They have a good reputation for water pumps in performance cars.
http://www.stewartcomponents.com/
Plan this job on my 1.9 this year but will probably opt for the more modest Meyle version for my little 4-pot engine.
http://www.ebay.co.uk/itm/370803906075? ... 1423.l2649
Mint
Post by Mint » Fri 10 Jan, 2014 22:49
Del wrote:...more modest Meyle version for my little 4-pot engine.
Interestingly the pump for my M54, 2.2, 6 pot is cheaper :? and it specifies a metal impellar.
http://www.ebay.co.uk/itm/Water-Pump-BM ... 5af5de0fdb
Sorry Woody :(
Fender2004
Post by Fender2004 » Sat 11 Jan, 2014 09:17
I'm sure a water pump from the dealers is around £100.
Post by Del » Sat 11 Jan, 2014 10:20
Mint wrote:and it specifies a metal impellar.
I suspect (I'm not 100% sure) that the infamous plastic impeller is on the 6-pot waterpumps. I remember a forum member Jonco changed his OE 4-pot waterpump recently and he had been surprised to find it had a metal impeller. :shrug
Jonco
Post by Jonco » Sat 11 Jan, 2014 11:00
That's true - as far as I know it was OE. I fitted a Meyler replacement but as already said it's about peace of mind. My rough calculation was if it lasts a further 60k, then based on average mileage I'll be 75+ (if I'm still here). Problem then will probably be holding water not pumping it :roflmao:
Woody1000
Post by Woody1000 » Sun 19 Jan, 2014 18:18
Fitted new water pump yesterday and the one I took out did have a plastic impeller and was the original from new and surprisingly it was in perfect condition !
Cooper01
Post by Cooper01 » Tue 06 May, 2014 12:50
Did you change the thermostat as well while you had the whole thing apart? What was its condition/ cost for new one/ purchase place? Thanks.
Post by Southernboy » Tue 06 May, 2014 16:15
....... I hate to say this, but you can buy a Meyle part with metal impeller locally in the UK for about 1/2 the price of OEM... :wink:
Woody1000
Post by Woody1000 » Sat 10 May, 2014 20:43
Yea I changed the thermostat as the temperature gauge never went to half way, a new unit fixed the problem for me. It's got to be worth changing as the plastic locating clips are prone to snap.
