Z3 1.9 exhaust
Matkat
Z3 1.9 exhaust
Post by Matkat »
Can anyone reccomend an aftermarket rear silencer with either an oval or double tail pipe which does not require any modifying of the bodywork. I have seen one advertised but it says body mod needed. Thanks
Re: Z3 1.9 exhaust
Post by BladeRunner919 »
Don't all the aftermarket ones have an oval tailpipe as standard?
Matkat
Re: Z3 1.9 exhaust
Post by Matkat »
Think your right. Was hopefully going to source a twin pipe alternative. Which system do you reccommend?
Re: Z3 1.9 exhaust
The cheapest. If you want twin pipes, just chop off the oval one and attach an aftermarket twin pipe trim. Otherwise you're into having a custom box fabricated.
Jonco
Re: Z3 1.9 exhaust
Post by Jonco »
If you are willing to go stainless i.e not cheapest - then Cobra do a standard oval pipe (I've got one on my 1.9) or Longlife will make you a custom built single or twin. No body mod needed but expect to pay ~£325 to £380 for cat back.
If you go cheap on ebay take care - there are many stories of units not fitting or hanging too low.
Matkat
Re: Z3 1.9 exhaust
Post by Matkat »
Thanks. I will look at Cobra... I dont do cheap anyway. :D
Jonco wrote:If you are willing to go stainless i.e not cheapest - then Cobra do a standard oval pipe (I've got one on my 1.9) or Longlife will make you a custom built single or twin. No body mod needed but expect to pay ~£325 to £380 for cat back.
