Rear Screen
Rear Screen
Has anyone really removed the line afross the rear screen.
I have tried without much luck and wonder how hard to polish.
Re: Rear Screen
I used Renovate (Bought off e bay), removed the milkiness but not fully the lines, was going to have another try but 2 rips appeared so new one to be fitted
Re: Rear Screen
Thanks Bowler. The line is noticable but not too bad. Really want to get rid of it but a bit scared about hoe hsrd to polish.
Re: Rear Screen
Greygate polish... If I recall, someone said it's what the airforce use to buff up the plexiglass canopy on the planes... Brass polish also works very well...
Re: Rear Screen
HiSouthernboy wrote:Greygate polish... If I recall, someone said it's what the airforce use to buff up the plexiglass canopy on the planes... Brass polish also works very well...
Here's the link if you need it
http://www.ebay.co.uk/itm/GREYGATE-PLAS ... 19c80d7bd9
Great results.......but you will never get rid of 100%
Dont forget to do inside & out
Good Luck
Re: Rear Screen
I've used Brasso on a couple of plastic windows but have been told that tis can cause the plastic to go brittle. Having said that I did it on one of my cars about 5 years ago and it's still fine and still nice and clear, it was quite bad so used a lot of brasso and a lot of polishing.
Andy
Andy
Andy
1999 Z3 2.8 RED, back with me
Re: Rear Screen
brasso seems to be a fairy common solution. I would have thought if it made the plastic go brittle (compared to the number of people who have used it) it would be quite infamous.
Re: Rear Screen
Greygate smells just like brasso and doesn`t get rid of scratches but does make the plastic a lot clearer in my experience.
Re: Rear Screen
There is a proper BMW cream, but I've found toothpaste to be quite good as well.
Re: Rear Screen
toothpaste is a great idea, its very slightly abrasive which is what you need. also a very fine rubbing compound would work. though toothpaste wont have any nasty chemicals which may effect the plastic, good call
Re: Rear Screen
or you could just cheat like me and get a tinted rear screen
Re: Rear Screen
littlefeller wrote:or you could just cheat like me and get a tinted rear screen
The original rear window from new was a green tint
Re: Rear Screen
Greygate plastic polish is a fantastic product. It will get rid of scratches BUT you can't do it on your own. You will need someone on the other side of the screen with a piece of wood or similar well wrapped in a towel or like to keep the window flat whilst you polish the other side!! Simples.
Re: Rear Screen
Thanks everyone
