Is this right I was in halfords and forgot my bit of paper with the oil I had written down!
Did I get the right diff oil?
Re: Did I get the right diff oil?
Yep...that'll do it...
But you can check in the Z3 Knowlwdgebase...I think all the various lubes are listed there...
Cheers I did check but it seems castrol have changed the oil names since then so was a bit confused!
Perfect for a car with no limited slip diff - used similar in mine.
I thought the Z3's had LSD?
I used castrol oil with LSD additive.
Only some of them.Keynun wrote:I thought the Z3's had LSD?
