cat removal
paganbronze
cat removal
Post by paganbronze » Wed 01 Oct, 2014 19:41
got a blow on mine and wondered if it could just be cut out and replaced with a straight thru
Re: cat removal
Post by Del » Wed 01 Oct, 2014 19:59
In my experience you may well struggle to pass a future MOT emissions test without a cat - particularly the test for CO.
paganbronze
Re: cat removal
Post by paganbronze » Wed 01 Oct, 2014 20:04
so which is the main cat? there are 2 up front and one at the back, are the front ones pre cats?
Re: cat removal
Post by Del » Wed 01 Oct, 2014 20:25
As far as I am aware, your car (2.8?) has a single cat at the front of the car just downstream of the dual pipe manifold run. There is a small mid silencer and the large rear silencer/twin tail pipe. The rear section on the Z3 exhausts is the section that tends to deteriorate with rust and this contains the mid and rear silencers. Eliminating one or both silencers will cause a noisier exhaust - which in the judgement of an MOT inspector may or may not cause a failure.
Other 2.8 owners may come along shortly with some practical experience/solutions, as replacement rear section Z3 exhausts are getting harder to obtain.
paganbronze
Re: cat removal
Post by paganbronze » Wed 01 Oct, 2014 21:11
mine, well, my partners, is a 1999 2.8 and the front seems to have 2 downpipes with a cat /lambda on each which goes into a single with a silencer. The rear has just the rear box....I think
Re: cat removal
Post by spurs fan in a coupe » Wed 01 Oct, 2014 21:21
paganbronze wrote:mine, well, my partners, is a 1999 2.8 and the front seems to have 2 downpipes with a cat /lambda on each which goes into a single with a silencer. The rear has just the rear box....I think
My 2.8 has one cat that comes after the 2 exhaust (exit) manifolds.
That leads to a mid silencer then into a rear silencer.
I have removed the mid silencer (replaced with a through section by a PowerFlow franchise), the cat on mine is empty and the back box is a Sebring. I love the sound but have to refit a normal cat for the mot
paganbronze
Re: cat removal
Post by paganbronze » Wed 01 Oct, 2014 21:38
Rafolian
Re: cat removal
Post by Rafolian » Thu 02 Oct, 2014 07:01
My '98 single vanos 2.8 has a single cat after the twin pipes from the manifold and this bolts to the the rear box, no centre silencer!
Z3 Mark
Re: cat removal
Post by Z3 Mark » Sat 04 Oct, 2014 08:37
And there I was reading the title thinking I may have found a solution to my problems...
:lol: :lol: :lol: :lol:
Mugs
Re: cat removal
Post by Mugs » Sat 04 Oct, 2014 20:08
basically......yes, you can.
i welded in straight pipe to get me by when my cat disintegrated internally.
as already stated, you will need to get a new cat for the mot. i got one from Euro car parts for £112 all in (incl delivery) with a 2 year guarantee.
the car will get a bit louder and smell a bit of exhaust fumes but it will get you by for a bit.
2400rg
Re: cat removal
Post by 2400rg » Wed 08 Oct, 2014 21:35
I have just had a new front end exhaust fitted.
And one lambda sensor is pointing down and left . What make of exhaust have you bought
Cooper01
Re: cat removal
Post by Cooper01 » Thu 09 Oct, 2014 11:16
Haha Z3 Mark.
I think a straight through twin barrel will get rid of your cat. Sorry, silencers are not made for shotguns. ;)
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 2 guests
