She shimmies like my sister Kate
mich
Post by mich » Thu 16 Oct, 2014 04:49
I have not posted here for a long while but would like to run this past our resident experts:
I have not taken the Z for a decent run for about 12 months so to day off I set for Taupo after 20-25k noticed a bit of steering wheel shimmy @50-55k/h that’s funny said me to Mrs mich, new tyres 12 months ago and recently had to have balanced for the 2nd time can't they do anything right mumble mumble etc etc….
Well it got progressively worse coming in at all speeds between 50 and 90k/h on two occasions it really started to shake as if on deep ruts could it be the brakes hanging on which had happened just after purchasing the car and gave similar symptoms???
After a bit of a walk around in Taupo, lunch etc we headed home the first 50k or so no problems then it started again coming and then disappearing it made no difference if I gently applied the brake or on a bend or accelerating etc so I am thinking …front dampers, steering joints (just passed its WOF) hydraulic knocking in power steering which I have never experienced but am deeply suspicious of but you would expect some difference on cornering, I will check oil level in the morning……??????
Has any one experienced or heard of this??
Re: She shimmies like my sister Kate
Post by Robert T » Thu 16 Oct, 2014 06:21
Stuck calliper springs to mind. Were any of the wheels hot?
Post by Del » Thu 16 Oct, 2014 13:21
I agree with Robert - this sudden "vibration" after a few miles and at moderate speed sounds like a sticking calliper. I had this happen to each of my front callipers within weeks of each other. As Roberts says, the "clincher" is that the wheel gets hot. One of mine got so hot it warped the little plastic BMW badge in the centre of the wheel. I replaced both with remanufactured (exchange) callipers and everything was perfect again. :)
Post by bertiejaffa » Thu 16 Oct, 2014 19:45
I had this recently - turned out I had a slow puncture and one wheel was lower PSI than all the rest
Brian4
Post by Brian4 » Thu 16 Oct, 2014 20:03
I would agree with sticking calipers as it is a well known E36 trait and especially as yours has not had much use in the last 12 months. The calipers can be cleaned up and resealed or replaced.
3.0I Topaz Blue
2000 E36/7 Z3 3.0i
2016 F31 335d
2015 F21 118i
Post by TitanTim » Thu 16 Oct, 2014 20:55
The front calipers are around £210 each :P
mich
Post by mich » Fri 17 Oct, 2014 05:14
Thanks every one for your comments, it does seem that the brakes are the culprit you can see the discolouration of the disc (rf) through the wheel. Hey ho more B&**#2 expense. :lol: :lol:
Scrapman
Post by Scrapman » Fri 17 Oct, 2014 18:19
So, tell me about Kate.........
mich
Post by mich » Fri 17 Oct, 2014 21:26
Scrapman wrote:So, tell me about Kate.........
A pleasure old chap..............
https://www.youtube.com/watch?v=6R4z_i1lN5c
Rocketbike
Post by Rocketbike » Sat 18 Oct, 2014 20:53
Have you got a picture?
Users browsing this forum: Bing [Bot] and 8 guests
