Hi all,
I've had a 2002 1.9 Zed for about 6 weeks, and a couple of weeks ago, the dreaded airbag light came on. Car was in the garage today to get some new suspension arms, and I asked the mechanic if he could clear the fault. He had a go, and told me his reader could not connect to anything airbag related. He confirmed that the connection with the car was good, as it could read no mechanical faults, but couldn't go into airbag side of it. Could it be the airbag module playing up? Having a good look around, I found that some airbag modules are read through round connection under bonnet, not long one under steering wheel. Could that be my case? Or, how should I proceed to reach/remove airbag module? And would a new one need coding?
Thanks again,
Boosh.
Airbag light... wit a twist!
Re: Airbag light... wit a twist!
Hi Boosh,
If you have the round 20 pin pac-man connector under the bonnet you will probably need to connect to that to read the airbag module.
Normally all that is available on the OBD 2 connector inside the car under the steering wheel is the engine management DME module.
Most likely cause of your airbag warning light is a dodgy connection under the seat but getting the code read and the module reset is a good start. Note that not all generic readers can reset airbag lights so it is best to go for something BMW specific like INPA.
For further info Robert T has a good thread on this forum (viewtopic.php?p=353834)
Let us know what you find and hope you get sorted soon.
You want one of these B800 Airbag Reset Tools to read the codes and reset
http://www.ebay.co.uk/itm/Memo-Scanner- ... 27e788f16a
2003 BMW 2.5 Z4
2003 BMW 2.5 Z4
where abouts are you? theres plenty of people with a reset tool
I'm in Salisbury, but would be quite happy to drive a little to get it sorted...
Thanks,
Boosh.
Thanks,
Boosh.
http://www.zroadster.net/forum/viewtopi ... =5&t=36055
Link to the thread with details of members with diagnostic kit, nearest to you seems to be zederbee in Basingstoke area, may be worthwhile to PM him to see if he can assist.
2003 BMW 2.5 Z4
2003 BMW 2.5 Z4
Well, it took me a little while, but I got myself a B800 SRS reader, as recommended.£15 posted. What convinced me to give a try was the £450 (!) quoted by an 'independent BMW' garage, to take the seat out and replace the airbag module. Using the code reader was very easy, once I realised that the fault had been logged in several times, and therefore needed clearing several times. Two days so far, with no airbag light on the dash. Needless to say, I doubt I'll be using that garage... Thanks all for your input,
Boosh.
Boosh.
ours only comes back on if you adjust the seat
Boosh wrote:Well, it took me a little while, but I got myself a B800 SRS reader, as recommended.£15 posted. What convinced me to give a try was the £450 (!) quoted by an 'independent BMW' garage, to take the seat out and replace the airbag module. Using the code reader was very easy, once I realised that the fault had been logged in several times, and therefore needed clearing several times. Two days so far, with no airbag light on the dash. Needless to say, I doubt I'll be using that garage... Thanks all for your input,
Boosh.
Amusingly you don't have to take the seat out to replace the airbag module, it is underneath the stereo above the clutch.
I had an airbag fault that I couldn't rectify, but replacing the airbag control module with one of exactly the same part number solved the problems instantly.
...and I bet it didn't cost £320 (albeit new) to fit either! Bloody rip off merchants!
