1997 Z3 2.8 - Vibration under hard acceleration
Keynun
Post by Keynun » Sat 24 Jan, 2015 18:48
Any ideas on what this could be? It only seems to do it after a few minutes of abuse. It's also more pronounced when going up a hill. If feels like it is coming from either the diff area or mid (prop bearing). The car does not vibrate when driven normally.
I replaced the propshaft guibo flex disc thing when the clutch was done 3 years ago so that's out of the question.
stu
  Z3 roadster 2.8 supe
Re: 1997 Z3 2.8 - Vibration under hard acceleration
Post by stu » Sun 25 Jan, 2015 15:32
I thought the LSD had a problem on ours which has also had a vibration under load. LSD found to be ok so now looking at prop shaft bearing.
Users browsing this forum: Baidu [Spider] and 4 guests
